Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 13-03-2015, 15:39
Fred326 Fred326 is offline
FRC #5442
Fred326 is an unknown quantity at this point
Getting value from Potentiometer on SRX Talon
Hi,
We're using a command based robot written in Java and trying to use a 10 turn precision potentiometer (am-2619) hooked into an SRX Talon for our lift system but we cannot figure out how to get the value of its rotation back from the Talon.
Unread 13-03-2015, 23:16
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Getting value from Potentiometer on SRX Talon
talon srx software reference manual
http://www.crosstheroadelectronics.c...ol_system.html
Unread 14-03-2015, 15:22
FRC #5442
We've tried using AnalogInPosition, getPosition, and AnalogInVelocity and the only one we get changes from is AnalogInVelocity.
Unread 14-03-2015, 16:17
Post a (focused) picture showing the connections at both the Talon end and the MA3 end.
Unread 14-03-2015, 22:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Go the talon page on web dashboard and make sure the input is reading correctly. Hardware wise it is easy to exchange the wiper with one of the ends of the pot. Makes for funky readings that sort of work
Unread 15-03-2015, 19:32
FRC #5442
I won't be able to get any pictures till Monday but thank you for your help so far.
Unread 17-03-2015, 09:15
FRC #5442
Here's the pictures. I wasn't sure what the MA3 was so I just took a picture of all the connections I could.
Unread 17-03-2015, 16:04
ozrien's Avatar
Omar Zrien
AKA: Omar
So what value did you get from getAnalogInPosition().
If it's near 0, then the analog input pin is being pulled to ground externally.
If it's near 1023, it's being pulled to positive voltage (greater then 5V at the analogbreakout input, or greater than 3.3V at the Talon input).
If it's near 100 then it's floating (not connected to anything).
Also it might just be easier to grab the self-test results in the web-based config (section 2.4). That will rule out bad code.
Use a DC meter to confirm you are getting 0 - 5V swing on the analog input pad on the breakout. Your MA3 might not be getting power. Rotate the mechanism slowly while monitoring the voltage of the analog signal.
Unread 17-03-2015, 23:22
FRC #5442
It was 102 so I'll talk to electrical about it tomorrow. Thank you for your help.
Unread 17-03-2015, 23:37
ozrien's Avatar
Omar Zrien
AKA: Omar
Yep sounds like it's floating (section 16.21 in Talon SRX Software reference manual).
