Go to Post We owe a lot to Bob (Hammond), he is a true gentleman. - Covey41 [more]
Unread 13-03-2015, 17:22
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
Robot Communication Problems
Hey, I'm a programmer from team 4780 and I have been trying to get our practice robot to drive. When I connect to the robot's wifi, it says the connection is limited. I have checked the roboRio's firmware and image. I also checked the connection between the roboRio and the bridge. When I go into the Driver Station, it says there is communication with the bridge, but the robot light and the DS Radio light are both not lit. Can anyone help? Thanks in advance!
Unread 13-03-2015, 18:39
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Robot Communication Problems
Windows will report that a connection is "limited" if it cant access the internet from the wireless access point. This is normal when connecting to a robot.
Have you tried walking through these steps?
http://wpilib.screenstepslive.com/s/...roubleshooting
What steps on that page do/don't work?
http://team2168.org
Unread 13-03-2015, 22:44
Unless you're using another Wi-Fi router as a "workgroup bridge" or something similar to connect to the robot's D-Link access point, there is no DS Radio in the system. That indicator should not light up on the Driver Station.
If you aren't able to communicate with the robot, how have you checked the roboRIO's firmware?
