Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 14-03-2015, 00:35
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
from LV or Java to C++ (urgent question)
Urgent question - Has anyone switched from LabView or Java to C++ on the robot? Did it require re-imaging? The Eclipse "Run As" feature looks to install the program AND change the startup scripts. I'm thinking re-imaging is unnecessary.
I'm asking this because we have a pit neighbor that really needs new code but I only do C++ (quickly) and re-imaging their roboRio might spook them.
TIA
Unread 14-03-2015, 00:38
Re: from LV or Java to C++ (urgent question)
No need to re-image regardless.
Going the other way (text based to LV) requires manually killing the running program or using the "No App" (not actually called that anymore) on the webdashboard.
LV or Java to C++ should be good to go with just a deploy from Eclipse.
