Go to Post I love it when there is someone that obviously "gets it". - dlavery [more]
Unread 03-02-2015, 18:42
2B || !2B's Avatar
2B || !2B 2B || !2B is offline
/* No Comment */
FRC #1559 (DevilTech)
2B || !2B is a jewel in the rough2B || !2B is a jewel in the rough2B || !2B is a jewel in the rough2B || !2B is a jewel in the rough
Text files on the roborio?
Hi,
Does anyone know how to write text files to storage on the roborio with java?
If so, what directories do I have access to?
Here's my code if it helps:
package org.usfirst.frc.team1559.robot;
import java.io.BufferedWriter;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
import edu.wpi.first.wpilibj.IterativeRobot;
public class Robot extends IterativeRobot {
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
	File f;
	BufferedWriter bw;
	FileWriter fw;
    public void robotInit() {
    	try {
    		f = new File("~/Output.txt");
    		if(!f.exists()){
    			f.createNewFile();
			fw = new FileWriter(f);
		} catch (IOException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
    	bw = new BufferedWriter(fw);
    public void teleopInit(){
    	try {
			bw.write("Hellow, I'm a text file");
			bw.close();
			fw.close();
With this code I get the following error:
java.io.IOException: No such file or directory
at java.io.UnixFileSystem.createFileExclusively(Nativ e Method)
at java.io.File.createNewFile(File.java:1012)
at org.usfirst.frc.team1559.robot.Robot.robotInit(Rob ot.java:32)
at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76)
at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)
ERROR Unhandled exception: java.lang.NullPointerException at [java.io.Writer.<init>(Writer.java:88), java.io.BufferedWriter.<init>(BufferedWriter.java: 101), java.io.BufferedWriter.<init>(BufferedWriter.java: 88), org.usfirst.frc.team1559.robot.Robot.robotInit(Rob ot.java:39), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]
WARNING: Robots don't quit!
---> The startCompetition() method (or methods called by it) should have handled the exception above.
Any help is appreciated!
There are no brakes on the software train
Unread 03-02-2015, 18:44
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Text files on the roborio?
I was able to create files by specifying a absolute path, i.e.:
/home/lvuser/Output.txt
Unread 03-02-2015, 18:47
We are writing files to /home/lvuser as described here: http://wpilib.screenstepslive.com/s/...15#FileStorage as well as to a usb drive at /media/sda1
Unread 03-02-2015, 18:48
2B || !2B's Avatar
/* No Comment */
Thank you so much!
I guess ~/ only works in desktop linux.....
Unread 03-02-2015, 19:13
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
You also can output to a flashdrive using /U/ and /V/.
Unread 04-02-2015, 10:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by 2B || !2B View Post
Thank you so much!
The ~ is normally interpreted by the shell, not the kernel. I believe that java is attempting to open the file directly through an fopen() or equivalent call. I believe that you can get the value of the HOME environment variable and use it in place of the ~ to avoid hardcoding paths.
        Map<String, String> env = System.getenv();
        f = new File(env.get("HOME") + "/Output.txt");
Unread 26-02-2015, 15:43
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Hi All -
I have looked around the links on this post for more information about using a USB stick, but can't find much.
I see that I can reference /U/ and /V/ (presumably for the two USB ports).
When I plug a Kingston NTFS-formatted USB stick and connect via FTP (Filezilla) I can see the KINGSTON device, but not the folders. I assume this is because the stick is formatted NTFS.
If I use a FAT-formatted USB stick, will I see it as /U or /V depending on the port it is plugged into? Any other fine points about getting this to work for data logging?
tia -
mp
Unread 27-02-2015, 10:46
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Originally Posted by shindigo View Post
Hi All -
tia -
mp
If you look above at what Joe Ross said I think that will answer your question. He says the USB drives will be mounted to /media/sda1
Unread 27-02-2015, 16:21
AKA: Mike Parker
FRC #0102
Sorry forgot to mention that I did look for /media/sda1, and I do not see the device listed that way. Neither do I see it listed as U or V.
I have since formatted my device as FAT and tried again with no luck. It is a 64Gb stick - any chance there is a size limit?
As an alternative I could use the internal storage. Read in the specs for the Roborio that the internal storage capacity is 256 MB. Can anyone tell what the approx remaining capacity is after loading JRE and robot program? Filezilla is not help me figure that out.
mp
Unread 04-03-2015, 18:48
AKA: Mike Parker
FRC #0102
Happy to report that I finally got this working using another smaller, FAT formatted USB stick.
Placed in the bottom USB port (the one closest the logo) this appears as: /u, /U and /media/sda1.
So I guess we should avoid NTFS and very large capacity sticks.
mp
Unread 06-03-2015, 21:28
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Note that it doesn't matter which USB port you plug it into. It matters what order you plug them in.
Unread 13-03-2015, 11:53
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
mp
This is probably a stupid question, but did you restart the robot after plugging in the flash drive? We've had to do this every time that we used one.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 14-03-2015, 00:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
FAT was traditionally limited to 4Gb. It seems to have been extended a bit. However, a recent search turned up:
You cannot decrease the cluster size on a volume using the FAT32 file system so that the FAT ends up larger than 16 MB less 64 KB in size.
It sounds like Micros*** is utterly muddying the waters yet again; this is worse than traditional by several orders of magnitude.
They also included on the same page, probably more germane:
You cannot format a volume larger than 32 GB in size using the FAT32 file system in Windows 2000. The Windows 2000 FastFAT driver can mount and support volumes larger than 32 GB that use the FAT32 file system (subject to the other limits), but you cannot create one using the Format tool. This behavior is by design. If you need to create a volume larger than 32 GB, use the NTFS file system instead.
Unread 14-03-2015, 01:01
I have never rebooted after plugging in a thumb drive and it has always worked.
Unread 13-04-2015, 19:15
ShortCircuit908's Avatar
ShortCircuit908 ShortCircuit908 is offline
King of Hacky Fixes
AKA: Caleb Milligan
FRC #4450 (Olympia Robotics Federation)
ShortCircuit908 is an unknown quantity at this point
Originally Posted by GeeTwo View Post
Another option is simply defining a non-absolute path, which would make the file relative to the working directory (where the jar file is located).
File file = new File("Output.txt");
Other than that, referring to solving "File or directory not found," you also have to create the directory that the desired file resides in, in addition to the actual file.
File file = new File("new_directory/Output.txt");
file.mkdirs();
file.createNewFile();
This would ensure that the directory "new_directory" is created before "Output.txt" is created.
