Go to Post A wise man told me a few nights ago, that it is important to own up to all your mistakes, so that others can see you doing that and wont deny and try to hide their own. - Josh Hambright [more]
Unread 14-03-2015, 10:33
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
Problem uploading code
When I upload my program to the practice bot, I am getting an error and I'm not sure how to fix it. This is my first year programming so any tips would be appreciated. This is the error in the Riolog:
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
ERROR Unhandled exception: java.lang.IllegalArgumentException: Subsystem must not be null. at [edu.wpi.first.wpilibj.command.Command.requires(Com mand.java:173), org.usfirst.frc.team4780.robot.commands.Elevate.<i nit>(Elevate.java:28), org.usfirst.frc.team4780.robot.commands.ElevateUp. <init>(ElevateUp.java:15), org.usfirst.frc.team4780.robot.OI.<init>(OI.java:5 9), org.usfirst.frc.team4780.robot.Robot.robotInit(Rob ot.java:38), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]ERROR Unhandled exception: java.lang.IllegalArgumentException: Subsystem must not be null. at [edu.wpi.first.wpilibj.command.Command.requires(Com mand.java:173), org.usfirst.frc.team4780.robot.commands.Elevate.<i nit>(Elevate.java:28), org.usfirst.frc.team4780.robot.commands.ElevateUp. <init>(ElevateUp.java:15), org.usfirst.frc.team4780.robot.OI.<init>(OI.java:5 9), org.usfirst.frc.team4780.robot.Robot.robotInit(Rob ot.java:38), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]
WARNING: Robots don't quit!
---> The startCompetition() method (or methods called by it) should have handled the exception above.
