Go to Post I'm a bit wary about playing on the new fields, however, because of the Carson/Carver/Hopper/Tesla Curse. I hear no alliance from those divisions has ever won championships. - [more]
Unread 14-03-2015, 10:33
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
Problem uploading code
When I upload my program to the practice bot, I am getting an error and I'm not sure how to fix it. This is my first year programming so any tips would be appreciated. This is the error in the Riolog:
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
ERROR Unhandled exception: java.lang.IllegalArgumentException: Subsystem must not be null. at [edu.wpi.first.wpilibj.command.Command.requires(Com mand.java:173), org.usfirst.frc.team4780.robot.commands.Elevate.<i nit>(Elevate.java:28), org.usfirst.frc.team4780.robot.commands.ElevateUp. <init>(ElevateUp.java:15), org.usfirst.frc.team4780.robot.OI.<init>(OI.java:5 9), org.usfirst.frc.team4780.robot.Robot.robotInit(Rob ot.java:38), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]ERROR Unhandled exception: java.lang.IllegalArgumentException: Subsystem must not be null. at [edu.wpi.first.wpilibj.command.Command.requires(Com mand.java:173), org.usfirst.frc.team4780.robot.commands.Elevate.<i nit>(Elevate.java:28), org.usfirst.frc.team4780.robot.commands.ElevateUp. <init>(ElevateUp.java:15), org.usfirst.frc.team4780.robot.OI.<init>(OI.java:5 9), org.usfirst.frc.team4780.robot.Robot.robotInit(Rob ot.java:38), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:76), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:234)]
WARNING: Robots don't quit!
---> The startCompetition() method (or methods called by it) should have handled the exception above.
Unread 14-03-2015, 10:36
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Problem uploading code
Please post your Robot class. Make sure to use code tags.
Unread 14-03-2015, 11:57
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
I have gotten this exact type of error before. Where it is naming a specific file and line (ex Elevate.java:28) it means there is an error in the file Elevate.java at line 28. You have to go through the error log and check the errors to see which lines in which files have errors. Then you need to fix them. PM me if you need more help.
Unread 14-03-2015, 23:02
FRC #4780
thanks for the help. I fixed this issue by going into Robot.java and putting the elevator object before OI.
