Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 14-03-2015, 18:15
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: What to use for ballast
why not use that extra weight to add functionalities or make your robot stronger?
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
  #32   Spotlight this post!
Unread 14-03-2015, 19:45
Jimbo2032 Jimbo2032 is offline
AKA: James Boring
FRC #3998 (BA Bots)
Jimbo2032 is an unknown quantity at this point
Originally Posted by cglrcng View Post
You mean my 50 lb glass vial of mercury as robot ballast won't fly during inspection? What if I just hide it really, really well? Guess I'll change that to a small steel cylinder of Hydrogen, Oxygen, or Acytelene then.
No.....lead and mercury are both "Hazardous Materials." (As are the others I listed). If added to your Robot that is.
Now, where did I attach that compact 20 lb. nuclear weapon I used as ballast the last time it was needed? (Use simple common sense please).
Edited for Addition;
Sure enough I missed reading Al's #3 fully above...(Wouldn't even attempt that personally, due to the multiple venues, schools, and commercial arena's, we compete at in multiple jurisdictions each season, not to mention that eventually someone may wish to resize the ballast for wt. reduction eventually). Sry Al.
Hyperbole is neither gracious nor professional.
  #33   Spotlight this post!
Unread 14-03-2015, 20:23
EmileH's Avatar
EmileH EmileH is online now
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
We used "Thirt" a solid aluminum cylinder for ballast in 2013 for our pyramid climber - and won Pine Tree with it.
Excerpt from our team website:
The Windham Windup, FRC Team 3467 Presents out mascot, Thirt!
Thirt is a solid piece of aluminum stock, 6 inches long with a diameter of 3.5 inches. He got his name because the atomic number of aluminum is 13.
Thirt became a member of our lives back in 2013, at the Granite State Regional. As a result of having some troubles with our robot, our shooter was removed, leaving only our climbing mechanism. Our sponsor, Veloxion, brought him to us as a counter-weight to move our center of gravity to directly below the arm. Because of him, our climber worked perfectly, allowing us to go on to win the Pine Tree Regional, and get an Excellence in Engineering Award specifically for our climber.
After GSR, our lead programmer fell in love with Thirt. He provided Thirt with his name and status.
The Windham Windup's Ultimate Ascent robot went from being a robot without a shooter to a robot that brought its team to the World Championship, thanks to Thirt. Because of this, Thirt has become a symbol of 3467's motivation and success.
Unfortunately in the years after 2013 we haven't had any weight left to use for ballast
2016-present: High School Student, FRC 1058 PVC Pirates
  #34   Spotlight this post!
Unread 14-03-2015, 20:57
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Do realize that if you ride in a motor vehicle with wheels, you likely have exposed lead weights on your wheels. Don't lick them.
One 18 lb counter weight we used is a plastic encased lead / sulfuric acid mix. The inspector didn't even count it against our weight limit. The other was a 4"x21"x1" chunk of steel. About 20 lb
  #35   Spotlight this post!
Unread 14-03-2015, 21:01
Pravin N's Avatar
Pravin N Pravin N is offline
FRC #1351 (TKO)
Pravin N is an unknown quantity at this point
We put rebar into our back 2x1 of our west coast chassis. Works like a dream, and it not visible at all (we made custom plugs).
  #36   Spotlight this post!
Unread 14-03-2015, 21:06
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Originally Posted by Grey Mann View Post
Weld all your scrap metal together and duct tape it to your robot. That works right..?
Please don't 'joke' about this. Duct taping 'ballast' to your robot will not make your inspector or FTA happy.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #37   Spotlight this post!
Unread 14-03-2015, 21:15
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
We use 1" x 3" steel bar cut to the precice length needed. Adjustable to any weight, fits in tight spaces, and easily drilled and tapped for mounting. No one knew, but there was 11.5 lbs. of such bar hidden inside the rear of the chassis of our 2013 robot, to manage CG for level hanging.
  #38   Spotlight this post!
Unread 14-03-2015, 21:26
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
This is a year where ballast is definitely a possibility for many teams.
My prognostication from game reveal day, and at least somewhat supported by week 1-3 results: This is going to be a landmark year for specialization and complementary alliance selection.
Even if I'm wrong, this is not an unreasonable place to be; several threads on CD have even focused on which specialties will be in demand. With that as a given, many robots will be simpler than in recent years, and will come in functionally under the weight limits. A significant number of these, (especially those whose design placed emphasis on mining the landfill, capping stacks, or scoring coop points on the step), will carry game pieces outside of the traditional "frame perimeter", and will be greatly assisted in stability by a chunk of metal at the back and bottom of the robot.
  #39   Spotlight this post!
Unread 14-03-2015, 21:53
Drive Coach
AKA: Antoine L.
Uranium could make a pretty heavy ballast as well
  #40   Spotlight this post!
Unread 15-03-2015, 01:41
TCMJ1816's Avatar
TCMJ1816 TCMJ1816 is offline
Peter
AKA: Peter Hartnett
FRC #1816 ("The Green Machine" (Alumnus))
TCMJ1816 will become famous soon enough
We came up with a fairly ingenious solution this year for ballast, we are using a 1" threaded rod the length of our back tube and we increment nuts on until we have our desired weight. Each 1" nut wights about 1/4 Pound which gives us all the variability we need. Another plus you touched on is its all COTS and fairly cheap (we found the nuts for under a dollar per and the rod was about $20)
  #41   Spotlight this post!
Unread 15-03-2015, 02:02
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Our ballast is a 250c Viair compressor and a 1/4 inch thick aluminum bellypan. due to upgrades at next regional, one has to go. I really like that compressor and replacing the bellypan doesn't sound terribly appealing either
  #42   Spotlight this post!
Unread 15-03-2015, 02:18
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Actually lead wheel weights have been outlawed in some states. http://www.leadfreewheels.org/ In addition the EPA has been "strongly suggesting" that tire stores choose lead free weights and that states ban the use of lead wheel weights.
Of course there are still millions of cars on the roads and wheels out there with un-coated lead wheel weights.
  #43   Spotlight this post!
Unread 15-03-2015, 10:17
Jimbo,
Had you been in California, it would have been a much different situation. Sealing/painting lead ballast is not something new to FRC. It has been around for more than a decade.
Lead wheel weights are also out of fashion for the same reason. Many locales do not allow them and some states ban hundreds of materials altogether.
Frank, I assume you are speaking of a battery used as ballast. Again this violates Robot rules and an issue was posted during last season here on CD discussing it.
  #44   Spotlight this post!
Unread 15-03-2015, 11:58
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Al,
Are you stating that the battery used for power on the robot cannot be used for ballast?
Hmmm, seems I need to figure out how to power my robot then
___________________
- Tennyson, Ulysses
  #45   Spotlight this post!
Unread 15-03-2015, 13:09
Originally Posted by jspatz1 View Post
No one knew, but there was 11.5 lbs. of such bar hidden inside the rear of the chassis of our 2013 robot,...
Anyone who read your Bill Of Materials should have been aware of its existence. Unless by "hidden" you mean "secret", in which case you were were not in compliance with the rules.
