Go to Post I've learned that the measure of success isn't the money you make, the education you get, or the car you drive. Your success can only be measured in the amount of people in whose lives you've made a difference and the size of your heart. - Amanda Morrison [more]
Unread 14-03-2015, 22:23
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: mjpg-streamer running on roboRIO
Originally Posted by cbf View Post
Have you guys run this during a competition yet? I would be concerned about the bandwidth taken by two simultaneous video streams. In the past, we've accidentally saturated the feed between our laptop and the robot with a single 640 x 480 stream.
Actually, you drop a Javascript page onto the ./www directory that has a button that allows you to switch between the streams. So, you're not getting both streams simultaneously unless you want them.
HTH,
Mike
