Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 14-03-2015, 17:02
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
Deploying Code...
Our programmer kept sitting in his chair and looking around. Thus, he was promptly scolded for not working. His response was "I am deploying code."
We needed a way to know when he was deploying code. Behold, the status flag&safety glasses combo.
L.A.S.E.R - Light Amplification by the Stimulated Emission of Radiation
Unread 14-03-2015, 22:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Deploying Code...
Unread 14-03-2015, 22:25
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Based on the long deploy time I take it you guys use labview?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 14-03-2015, 23:01
A Sentient Being
We use C++. It doesn't take terribly long to deploy, but it is long enough for someone to notice.
Unread 14-03-2015, 23:15
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
We're using Java, and it's 10 seconds. That is barely noticeable.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 15-03-2015, 00:12
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
With an i7, it still takes us about 2-3 minutes to build/deploy code with LabVIEW.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 15-03-2015, 00:14
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
We are using java with an i7 and have had compile and deploy times as quick as 7 seconds, but the average for us is somewhere around 12 seconds.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 15-03-2015, 08:07
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
We use C++ and an i5. Our build and deploy times are around 30 seconds for small changes. (And several minutes for large changes.)
Unread 15-03-2015, 08:54
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
You do know that you don't have to build the code every time you want to run it, right?
You can simply go to Robot Main.vi and run it from there. It takes us about 15 seconds to deploy the first time, and around 3 seconds after that until we reboot.
You only need to build/deploy/run as startup when you are done with your code.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 15-03-2015, 10:23
pastelpony's Avatar
AKA: Zach M
I've known about the run from robot main.vi but I never really used it. I've just got used to the whole build/run as startup protocol. I'll actually try to start running through there. Thanks.
Unread 15-03-2015, 10:42
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Another LabVIEW trick, code in dashboard variables for any variables you have in your code (works out really well for autonomous). This allows you to easily test your autonomous code and modify any values without having to stop and change in your code. Once you hit the right combination, screenshot your dashboard, and go back to your code and replace the dashboard variable receive function with the variable it is supposed to be. This is useful in competition, we were able to fully debug an autonomous in one practice field time in this method, and we ran it 5 times in a row during this same session to make sure it would run consistently on the field.
The running from robot main method works great when you are in your shop, i just get a little wary about possibly forgetting to rebuild and redeploy the code before we go out onto the field.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 15-03-2015, 10:55
pastelpony's Avatar
AKA: Zach M
I've been doing that for a while and had that set up this season, though from it's usage, I found that using time controls with autonomous has proven to be unreliable and will in the future try to use encoders + PID.
Unread 15-03-2015, 13:25
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
I need one of these.
Too often I have mechanicals yelling at me, "What's the hold up?" when they're waiting for the robot to do something.
Darn mechanicals.
Head Programmer / Driver
Unread 15-03-2015, 14:10
If you're using LabVIEW and trying to "Deploy" code, you're doing it wrong. There are legitimate reasons to use "Deploy", but I can't think of any that would be of use to an FRC team.
It takes only about ten seconds to send a LabVIEW program to the robot using "Run as Startup". Doing the "Build" beforehand can be several minutes, but it doesn't interfere with anyone running the robot. You don't even need to have the robot connected, or even present, to "Build" the code.
When you're doing interactive development/debug sessions by "Run"ning the Robot Main vi, sending all the code to the robot does take about the same amount of time as compiling it with "Build", but only once at the beginning of the process. Thereafter, it is only a few seconds to send only the changed code and run it again.
