Go to Post Automonous - n. the frequent sound made by a team member not wearing a watch. ex: Do you know automonous? - Cynette [more]
Unread 14-03-2015, 22:27
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: mjpg-streamer running on roboRIO
Originally Posted by emileh3467 View Post
How do you display it on the PC, thru smartdashboard or VLC? And does the FMS allow for communications over the ports used?
Actually, a simple web browser will do the display just fine. You can compile mjpg-streamer for vlc, udp, rtsp or one of several other options. However, we've just been using the output_http.so plugin and Chrome, Firefox or IE to display it on the DS. You can even make it start automatically just like the dashboard normally would if you want to.
HTH,
Mike
