Go to Post This forum is a really great tool to get people connected to the rest of FIRST communities, as well as a great place to learn from other people and share a little part of yourself. - Ken Leung [more]
Unread 14-03-2015, 18:18
michaelyork michaelyork is offline
FRC #3680 (Elemental Dragons)
michaelyork is an unknown quantity at this point
Question Converted 2015 code to 2014 Java | Nothing Working Well
Hello,
I have tried to convert my 2015 code to 2014 libraries. I converted it and fixed most of the errors. I had to change the types of the motor controllers all to jaguars. When I try to use the buttons or drive the robot, none of the controllers run. They stay blinking yellow (orange?) after booting the robot. Below is my code on GitHub. I have tried lots of stuff, any ideas?
https://github.com/Team3680/2015on2014
Thanks!
Michael York
Unread 15-03-2015, 10:58
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Re: Converted 2015 code to 2014 Java | Nothing Working Well
Are you using jaguars on the robot? I think the main reason for the switch was to get an expanded control system, which might be why you are having errors. I would recommend staying with 2015 Java as it is designed for the 2015 system.
Unread 15-03-2015, 14:33
I converted it to the 2014 system because the only other robot we have uses the cRIO, we couldn't afford another roboRIO.
