Go to Post The best teams have students who genuinely enjoy scouting and the alliance selection process. - Jay O'Donnell [more]
Unread 03-15-2015, 02:57 PM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Dashboard Saving Values
I was wondering what the best way to save values on the dashboard. Anyone have any suggestions
Unread 03-15-2015, 03:29 PM
FrankenmuthK's Avatar
FrankenmuthK FrankenmuthK is offline
FRC #5215
FrankenmuthK is an unknown quantity at this point
Re: Dashboard Saving Values
If you go to the dash board code you need to put the values in then right click and set it as default
Unread 03-15-2015, 03:32 PM
Bpk9p4's Avatar
FRC #1756
That is what we are doing now. No was just wondering if there was an easier way to do it whill code is running
Unread 03-15-2015, 04:08 PM
Bpk9p4's Avatar
FRC #1756
Unread 03-15-2015, 04:28 PM
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
You cannot programmically 'set default value' on a front panel object, as this value is compiled into the code.
Instead you could implement a config file. When the dashboard first loads you can read the value stored and set the front panel object. And when you want to save it you just overwrite this value. LabVIEW's ini file pallette works well for this, under Programming --> File I/O --> Configuration File VIs,
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 03-16-2015, 10:39 PM
Bpk9p4's Avatar
FRC #1756
Do you have an example of how to do this
Unread 03-16-2015, 11:54 PM
wt200999's Avatar
Texas Instruments
AKA: Will Toth
These two VI Snippets attached show an example of initialization and writing the value. The config file would then look something like this:
[Defaults]
KeyName = 5.000000
ID:	18663  Click image for larger version
Name:	Write Value.png
