Go to Post The stated goals of FIRST are to inspire a culture that values science and technology. Inspiration needs Motivation. What motivates people? Competition. - Dmentor [more]
Unread 17-02-2015, 20:06
FancyGerald FancyGerald is offline
FRC #3098
FancyGerald is an unknown quantity at this point
USB Camera name randomly changing
My team has plans to use two different USB cameras both plug into the same robo-rio. When we started to the use cameras we were working with only one, and that camera was give the name "cam0". we had written code to use "cam0", then we started to have issues because the name of the camera had changed to "cam1". so we wrote code to handle the seemingly random name changes for the camera. now that we have started to toy with two cameras the bot has now given the new camera the name of "cam2". but not only has it given it the name of "cam2" it only names it that way if its plugged into the port closes to the edge. why aren't the names consistent and if there is how could I change the names of the cameras?
Unread 18-02-2015, 09:11
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
Re: USB Camera name randomly changing
Are the cameras assigned names in OI?
Unread 10-03-2015, 13:43
Crossle86's Avatar
Crossle86 Crossle86 is offline
Software Engineer
AKA: Richard Corn
FRC #4450 (Olympia Robotics Federation)
Crossle86 is an unknown quantity at this point
This issue is a problem for our team as well.
Unread 14-03-2015, 12:01
Autonomous Queen
Any updates on the issue? Have you got it working yet?
Unread 14-03-2015, 12:26
Crossle86's Avatar
Software Engineer
AKA: Richard Corn
Sorry I havent updated this been wall to building. We opted for a properties file on rio which identifies which rio and thereby which camera names are available. Works fine and the properties file can be used for other configuration data if the need arises.
Unread 15-03-2015, 16:37
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
would doing a directory listing on /dev and look for the cam* devices be useful?
Unread 16-03-2015, 16:54
Crossle86's Avatar
Software Engineer
AKA: Richard Corn
That sounds good but a look at /dev shows no cam* devices even though we know cam1 exists as a usb device on the rio usb port.
Unread 21-03-2015, 11:35
Autonomous Queen
Have you gotten the camera names from the roboRIO? Go to roboRIO-xxxx.local while connected directly to your roboRIO where xxxx is your team number. The cameras each get their own names assigned to them by the RIO. Plug in both the cameras and it should show the names of the cameras. Use those names in Robot.java to run the cameras
Unread 21-03-2015, 20:56
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
I had this issue with a team; the only thing that worked was reflashing the cRIO to change the camera back to cam0. I agree though its really annoying and should be configurable.
