Go to Post Who would think 130 points would be a losing score! - Chris Fultz [more]
Unread 09-03-2003, 22:52
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Taking pics at FIRST events... Tips needed
Do you guys have any good tips for taking pics at FIRST competitions?
All input is wanted!
p.s. why do digital cams blur more than 35mm?
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 09-03-2003, 22:55
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Point, [zoom if needed], Press button...
Pictures of action are better than after action pictures.
Don't take a picture of scores, unless it's a really good score (Like the 700pt matches at nat's 2 years ago).
Pick a subject, center it, capture it. Those look better than random bot's on a field.
Unread 09-03-2003, 22:58
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Try to get as many pics as possible in the pits, it is just easier that way. oh also while getting pics make sure you try to get pictures where you are able to SEE the numbers. makes life a lot easier.
Unread 09-03-2003, 23:16
You should check your camera instructions. If the camera is set to have a shutter speed below 1/60 second then any motion will blur including film cameras. Many people get excited at competition and with lightweight, digital cameras, they have a tendency to push too hard on the shutter button. This causes the camera to move while the shutter is open and hence the blurring. Being zoomed in for a closeup makes the problem even worse. So, set your shutter speed for 1/125 or higher if you can, get closer to the action, and gently press the shutter. Some photographers will tell you to take a breath and hold it while you press the shutter and then release.
Unread 10-03-2003, 00:21
MissInformation's Avatar
MissInformation MissInformation is offline
falling can be fun
AKA: Heidi Foster
FRC #0116 (Epsilon Delta)
MissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond reputeMissInformation has a reputation beyond repute
If you have a digital camera that has the sequence mode, use the sequence mode for action shots, just make sure you have a lot of memory cards. I liked taking shots of the robots as they hit the wall of bins, so while the human players were doing their thing, I would focus on the bins and hold my shutter release down half way and wait... got some decent photos this way.
And if your camera has multiple settings, make sure you check them before you start taking pictures.
And even if you don't have a sequence mode, make sure you have lots of memory cards so you can take lots and lots of pictures. I took over 800 photos at VCU.
And make sure you have a good photo editing program...
MissInformation
Time it was and what a time it was it was
A time of innocence
A time of confidences
Long ago it must be
I have a photograph; preserve your memories
They're all that's left of you -Simon and Garfunkel
Unread 10-03-2003, 00:40
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
rules of good composition
-no posing
-do not put subject in the center of the picture
-framing (like a tree or sign in the side or corner... or top)
-leading lines, like a path of travel such as a road or an aisle in a pit
-balance (sorta like symmatry)
-look for cool patterns
well thats all i remember from photography class... here's an example
Name:	woodie\'s shirt 2 (smaller).jpg
Unread 10-03-2003, 01:27
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Another tip: If your shot has human player bins in it, don't use flash. The flash will reflect off of the retroreflective tape, throw off your camera's light meter, and your picture will come out black with a few white lines in it.
Zan Hecht
Unread 10-03-2003, 17:54
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
The retroreflective tape combined with a flash can make for some very cool tron looking photos. Not very functional but very nifty.
Retired member of Team 108
Unread 10-03-2003, 20:46
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
I had alot of problems with retro tape at brunswick eruption, be careful where you point!
check out what retro tape can do in the bruswick eruption off season pic thread.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 10-03-2003, 21:24
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Wait, so 1/125 is higher then 1/60? How can things get blurrier by being further below 1/60th second? Doesn't shorter exposure time lead to less blurry pictures?
Silly cameras.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 10-03-2003, 21:31
SkitzoSmurf's Avatar
SkitzoSmurf SkitzoSmurf is offline
Ricksta Happens
AKA: Talon
#0121 (Rhode Warriors)
SkitzoSmurf is an unknown quantity at this point
Send a message via AIM to SkitzoSmurf Send a message via Yahoo to SkitzoSmurf
ummm, one tip, first nationals fireworks are pretty, but dont turn out in pictures.
90|>'5 ß|_|5y, ¢4|\| 1 |-|3|_¶ y0|_|?
Unread 10-03-2003, 21:43
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I found that out last year. I couldn't see a thing in the pictures. Don't take pictures on a rollercoaster, either. Doesn't usually turn out (though I've seen a few that have).
Jeff Waegelin
Unread 10-03-2003, 21:55
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
if your camera has an autofocus, hold the shutter button halfway down for a second so that the camera can check it's white balance (if it does that) and focus on the subject. This is even more important if your camera has a multi-point AIAF, where you have to check if it's focusing on the right spot.
Otherwise, if you push it down really fast, it has to calcualte white balance and autofocus before it shoots, making the shot delayed.
I mistakenly set my camera for 1 second shutter speed during the second half the build period and didn't check it until after we shipped. Needless to say, I have cool, albeit REALLY BLURRY pictures
We were the first seeded first-year team at a first-year FIRST regional.
Unread 10-03-2003, 22:04
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Silly cameras.
Greg
1/125 is less time than 1/60. The faster the shutter, the least amount of movement you will get. Longer shutter time will get more detail, but if the camera, or object is moving, it will blur.
I just bought my camera for the competion, has shutter speeds of 15 seconds, to 1/1500 of a second.. so I should be good. I will also try out the multiple shots per second thing for action thing.. sounds cool.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 10-03-2003, 22:08
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Camera Balance Settings
Okay, one thing that I see A LOT in pictures is the color balance. Especially at competitions or indoors under florescent lighting, pictures often have a very pronounced red or yellow tinge. With a digital camera, this is really easy to fix, but most people don't do it and they're pictures don't come out as nice as they should.
Look for a setting called "White Balance" or something with just "Indoor" vs. "Outdoor" (vs. "Auto"). I found that in my expierience, Auto mode gets the right balance less than half the time - if you're at a competition all day long, you might as well keep the camera set to Indoor balance mode or manually tweak the white balance. Your pictures will be a lot nicer.
To show you what this is all about, I dug up two pictures from the NYC regionals. The first picture was taken with the wrong balance setting - you can clearly see the red tint to everything. The second one was taken with the correct settings. Comparing them, you can clearly see that just a few seconds of flipping through the camera settings makes a world of difference.
I also ran the first one through the Photoshop Color Balance tool. You can see that with Photoshop, you CAN correct the balance somewhat. However, Photoshop compensates for the red tinge by increasing the intensities of cyan and blue. You can see that I brought the carpet to a 'natural' look, but in exchange, everything else now has a blue tinge to it.
Long story short: unless you have the time to tweak each individual section of a picture for 30-60 minutes in Photoshop, take the few seconds to find the Balance tool on your camera. Makes all the difference in the world.
(You can also see what people meant when they said flash+retroreflective tape is bad. However, I personally think the effect is pretty cool).
(Excuse the bad quality - I had to use quite a bit of compression to get the file to fit inside the max upload size limit).
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
