Go to Post What about marriages ended by FIRST. I know that by Presidents Day my wife is not real happy with me :) - IndySam [more]
Unread 15-03-2015, 19:51
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Re: how to set Axis camera IP address for FRC PC Dashboard
Oh, and we can see the camera from a web browser, and have named it axis-camera.local successfully ...
Unread 16-03-2015, 07:12
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
In the 3/10/15 Team Update, there is a SmartDashboard update to provide a connection to Axis Cameras.
http://www.usfirst.org/sites/default...le20150310.pdf
Unread 16-03-2015, 09:14
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If you are running a static IP on the camera & DHCP on robot/DS, I would be surprised if the camera works in the pit at competition since DS & RoboRIO fall back to default IP without a DHCP running. Note this does not apply to USB cameras.
Unread 16-03-2015, 14:01
I think you need to name it axis-camera without the .local part.
Unread 23-03-2015, 08:02
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Are you running an m1013? I've had some problems with these. Can you confirm that your roborio is 10.te.am.2 and ds is 10.te.am.5? M1013s dont work well with mDNS.
I also had an issue where a team recompiled the dashboard and overrode the default camera ip finder to specifically use axis-camera.local which causes issues because the default LV dashboard has other camera finding techniques built in
Unread 23-03-2015, 08:35
The Axis camera is connected into the bridge and unless you are doing onboard images processing, which is unlikely this year, the roboRIO isn't even involved. You are using the PCs mDNS services. You should be able to ping with the axis host name, log in from a web page using the name, and connect from he dashboard using the name. In many cases, the Axis camera host name is actually Axis-serialNumber. I'd recommend setting it to Axis-camera. Then you can access easily when devices are set to use DHCP and link-local IPs. It will also work with static, but at that point all devices will need to use static.
The default dashboard uses the camera name, as sent back by the robot code. If you hard-code that in the dashboard, it should cause no harm and in fact works around some pesky TCP reconnect bugs that can happen in the kickoff code.
Greg McKaskle
Unread 23-03-2015, 09:17
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Originally Posted by Greg McKaskle View Post
The Axis camera is connected into the bridge and unless you are doing onboard images processing, which is unlikely this year, the roboRIO isn't even involved. ...
...The default dashboard uses the camera name, as sent back by the robot code.
Hey Greg, if we are doing no vision processing on the roboRio how do we "send back" the camera name from the robot code?
TIA
