Go to Post Wait, robot? We've been working on building a team. - rtfgnow [more]
Unread 16-03-2015, 07:57
Re: PCM
When you report a failure of the PCM here, can you add a little detail? What compressor type and how big a pneumatic system you have. (tanks and actuators please)
Unread 16-03-2015, 08:15
rjmah rjmah is offline
rjmah will become famous soon enough
Re: PCM
Pretty sure it was this year's compressor, two of the old small capacity aluminum reservoirs and a single solenoid and a 10 inch stroke cylinder. Now that you mention multiple solenoids, team 2013 seemed to have problems with their PCM too and they had 3 double acting solenoids.
Yes the frame shorting was addressed.
Robert Mah
Team 1246 Agincourt Lancers
Unread 16-03-2015, 08:45
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Re: PCM
Those of you having problems: If you haven't yet, email CTRE at support@crosstheroadelectronics.com with as much detail as you can provide. They can probaby either help or will be interested in understanding how it failed so that they can improve the design.
--Jacob
Illinois FTC FTA
Unread 16-03-2015, 10:14
The Lucas's Avatar
CaMOElot, it is a silly place
Re: PCM
On Team 365, we have a PCM that was dead on arrival (DOA). Team 4342 was generous enough to loan us their PCM while 365 goes through the RMA process.
Skipping to the cause of the failure, there is a solder joint fracture on one of the surface mount chips. This failure is unlikely to happen to any team with a currently working PCM (ours was DOA) so I will just briefly describe some of the symptoms:
First, this was a failure on the solenoid channels, compressor circuit worked fine.
Solenoids never switched on any of the channels. Webdash recorded a solenoid voltage of 3V, voltmeter could never pickup any voltage from the channels.
Initially, the channel LEDs would sometimes flash on momentarily (before a fault was indicated) and displayed some weird behavior (glowing faintly while off). Later in testing they were always off (I suspect the vibrations of the compressor made the solder joint connection go from intermittent fully off).
Frequent Solenoid Fuse faults reported on the webdash (both sticky and now). Status light was usually blinking red once. Faults were so persistent, they were difficult to clear (got some ironic Self Test messages indicating Faults with a message at the end that says "all faults cleared"). Occasionally, I could get the faults cleared and status lights normal. Once I turned on a channel (with nothing connected) the fault would return.
Robot Inspector
