Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 16-03-2015, 16:30
Re: Inverted Axis Problem
If you didn't change any code, then it sounds like you might have changed the wiring (or Jaguar ID numbers, if you use CAN).
If nobody admits to having changing anything, then why it changed is likely to remain a mystery.
