Thread Tools |
Rating:
Display Modes |
Re: Safety Issue: Robots Moving in Pits
Just make one for your own robot guys. |
To be clear, this is at least slightly tongue-in-cheek. But there seems to be a lot of "my solution is foolproof, but here, let me build a better fool to break yours" going on. I have no reason to believe that this rig will actually harm anyone at SBPLI, and commend the effort towards what I hope and believe is a full spectrum attempt at safety culture. Kudos. At the same time, I think we're all simply cautioning that, regardless of your solution, common sense/safety culture is still necessary to implement it properly. Raising the wheels is by no means an entirely safe solution. In fact, I can think of specific cases in which allowing the wheels to spin under power is more dangerous than actually controlling that power digitally or electrically. Again, it takes critical thinking. Anything anywhere in life that is sold as a perfect solution comes with the danger that users will stop thinking about its risks. |
Indeed, for much of the development of the TechnoKats' mecanum software this year the wheels would have a fit if they were lifted from the ground. The robot would jerk back and forth as the wheels convulsed, and it could easily have rocked itself off a set of blocks. Using closed-loop speed control does not play well with unloaded motors.
I guess I'm picturing jacking the robot up like a car then testing the wheels. Is there really that much sideways movement when your run the wheels off the ground? |
What would you tell a team trying to test a drive running PID in their pit? Put it on the floor? |
#7
Back in the IFI controller era many years ago, we did run a robot on the floor in the pit in order to tune and test the autonomous drive routines. We didn't run the actual auton code, just some test commands through the serial "program port" link to tell it to drive forward or backward six inches, or to rotate left or right ten degrees at a time. We did a six foot run once or twice, with advance warning to our pit neighbors and a couple of lines of students making sure nobody was going to be in the danger zone. And always there was someone prepared to slap the big red Emergency Stop mushroom on our auton/disable dongle. |
