Go to Post This 6 weeks of work, sweat, thinking, designing, building, talking, discussing, turning wrenches, wiring, programming, drawing on chalk boards, eating pizza, drinking mountain dew, with the students - is what the FIRST experience is really about. - meaubry [more]
Unread 16-03-2015, 20:45
rainbowbear998's Avatar
rainbowbear998 rainbowbear998 is offline
FRC #4739 (Thunderbolts Robotics)
rainbowbear998 is an unknown quantity at this point
Best way to cool CIM motors?
After competing in the Australia regional, my team have found that our winch motors (two CIMs on a tough box mini) get quite hot during matches, as we have them running to compensate for the weight of the boxes so we can kept them off the ground.
What is the best way to cool these? From what I've read, the heat sinks aren't that effective. At the moment, I'm working on mounting a 120 mm computer fan to cool them. Has anyone tried this? Does it work?
Unread 16-03-2015, 20:54
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Best way to cool CIM motors?
For immediate results in a pinch, you can use an can air duster upside down so it blows out liquid. It works well in a pinch, but the best solution to your problem is to equip some kind of braking mechanism like a bike disk brake and caliper attached to a servo or pneumatic cylinder so that you don't have to constantly run the CIMs at stall to hold a stack. A fan may work reasonably well, but trying it out is the best way to see for yourself.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 16-03-2015, 21:02
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Don't know about your design, but you might also want to look at a counterweight or constant force spring to help reduce the load.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Keep them cool by not running them. It may sound a bit snarky, but in this case it sounds like you're basically spending a lot of time with the motors stalled (i.e. putting power into the motor, but getting no motion out). That's a good way to both heat up your motors and run down your battery fast.
I'd suggest looking for alternate solutions to the gearbox. Many worm-gear drives are not back-driveable. You may instead be able to add some sort of break system. Look for solutions that allow you to hold the totes off the ground without running motors to do so. Many teams use window, van door, or snow blower motors to drive winches. They aren't as fast or as powerful as CIMs, but they also aren't back-driveable (thanks to the attached wormdrive gearbox).
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 16-03-2015, 21:03
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
At the New York Finger Lakes regional in 2014, Team 20 had a similar problem. As a result of 3 back-to-back matches, we had noticed that our CIM motors had become exceptionally hot, due to heavy defense. For the remainder of the event, we cooled our motors using canned air.
Upon returning, we decided it would be best to have a more permanent solution, so we redesigned the wooden block that we used to secure our robot on our cart. We added 4 powerful computer fans donated by a local company, placing them so that they would sit under the drive motors when the robot was placed on the cart. It worked well for us, especially during our summer IRI drive practices, as our practice field is not air conditioned.
Edit: If you are using a computer fan, make sure it is not attached to your robot during a match.
Unread 16-03-2015, 21:10
Thanks for the ideas everyone!! I saw a team with a pneumatic disk brake system which seems to work quite well. Unfortunately that won't work with our design though. I'll look at using the window motors we got in the KOP, but our carriage that our forklift mechanism is attached to is made of 2mm steel tube, so it's quite heavy.
I agree that a physical mechanism is the best method, but due to budget constraints we don't have any pneumatics. Can I ask why computer fans shouldn't be mounted to our robot?
Unread 16-03-2015, 21:19
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Some computer fans can be mounted to your robot.....specifically, the ones that came in the Kit of Parts this year, or the ones available from FIRST Choice, this year. Other computer fans, no.
Fans are considered to be motors, and there are very specific rules about which motors you can use on the robot.
Unread 16-03-2015, 21:20
theCADguy's Avatar
AKA: Sean Gibbons
Team Role: CAD
There are only certain motors allowed on the robot, listed under R18. The only computer fans allowed on the robot are the tiny ones included in the kit of parts, or that come with COTS motor controllers. I wouldn't expect any of these options to be very successful in cooling a CIM.
The fans we used were very large, and were designed to cool large server computers, and could provide a flow rate of more than 100 cubic feet per minute.
Unread 16-03-2015, 21:25
At the moment I'm considering a loose piece of surgical tubing going from the top of our frame down to the carriage, which will tighten as it lowers. It won't be enough to fully hold the carriage, but it should be enough to take some of the stress off the motors.
Thanks for all the replies!
MrForbes's Avatar
AKA: Jim
This one is pretty good sized, and will move a lot of air
http://firstchoicebyandymark.com/fc15-117
We use several pieces of surgical tubing to help hold up our container arm, and reduce the load on the motor. works good!
Unread 16-03-2015, 21:31
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Thumbs up Re: Best way to cool CIM motors?
Large mass of CIM is too great for air cooling to be effective within a match (between matches it may help depending on time to next match)
suggestions:
Alter gearing to reduce the hold current (at cost of speed-time to position)
(assuming CIM use=servo position mode w/sensor feedback to "hold" position)
or
Conduct CIM heat to largest robot frame for most effective thermal transfer during match
otherwise:
perhaps a latch via pneumatics or disc brake though this adds "time" to position/re-position but reduces CIM generated added heat during a "hold" to zero
the heat in the "held" CIM is produced by V^2 / R:
12^2 =144 / ~.1ohm 14.4 watts
or I^2*R of which I is being constrained to hold a position
decreasing hold current by more gearing is effective: generates less heat
(less I effectively produces less average voltage proportional to PWM duty cycle)
"R" contributors:
1. commutator:carbon-CuBrushes + 2. armature wire & crimp resistance
CIM heat is primarily removed via conduction via shaft & bushing closest to commutator
between matches the fasted way to reduce CIM temp would be to have a massive pre-cooled heat sink ready to physically attach to the CIM/Gearbox/Chassis area in prep for the next match
Good luck...
Unread 16-03-2015, 21:33
I just read R18 in the game manual, and with regard to fans, it states:
"Hard drive motors or fans that are included in the 2015 Kickoff Kit, 2015 FIRST Choice, are a part of a legal motor controller (including manufacturer provided accessories), or COTS unlimited computing device"
Would any computer fan be counted as a COTS unlimited computing device?
Unread 16-03-2015, 21:34
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I recommend liquid nitrogen.
MrForbes's Avatar
AKA: Jim
The fan has to still be in the COTS computer device, for it to be legal. Read through the Q&A for an explanation.
Unread 16-03-2015, 21:36
Oh god... Please no.
Thanks to MrForbes for clarifying that rule.
Back to my surgical tubing idea!
