Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
Unread 16-03-2015, 21:38
John Retkowski's Avatar
John Retkowski John Retkowski is offline
Team 316 mentor
AKA: Wyatt. Call me Wyatt.
FRC #0316 (LuNaTeCs)
John Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of light
Re: Best way to cool CIM motors?
It may not be applicable or the best solution to your problem this late in the season, but our team used a different motor/gearbox for our winch. We took the planetary gear box out of a drill and hooked it to a banebot 775 motor. This allows us easy lifting with no back driving or stalling.
2015 MAR District Championship #1 seed Winners (w 225 & 203)
2015 Upper Darby District #2 Seed Finalist(w 272 & 5420)
2015 NE Pioneer Valley District #3 Seed Finalists (w 61 & 663)
2014 Lenape Seneca District Champions (w 3929 & 2559)
2014 Springside Chestnut Hill District Champions (w 225 & 1495)
2013 Lenape Seneca District Champions
2013 Springside Chestnut Hill Finalists
Unread 16-03-2015, 22:04
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Depleted uranium tie wrapped to the frame of the robot.
Whoops, wrong thread.
If you need more lifting than surgical tubing, lengths of bungee cord also work.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 16-03-2015, 22:14
rainbowbear998's Avatar
rainbowbear998 rainbowbear998 is offline
FRC #4739 (Thunderbolts Robotics)
rainbowbear998 is an unknown quantity at this point
Time isn't really an issue for us, as we are now refining our robot for our next event, which is an off season event in June. Unfortunately here in Australia we aren't as spoilt for choice with regionals as in the US!!
It seems that having a worm or planetary gearbox is the best option to stop the motors heating up at the moment. I have one question though - will they perform ok with a few kilos of weight on them?
Unread 16-03-2015, 22:20
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
We designed part of our lifter gearbox with VEXPro versaplanetary gearboxes. However, I would check your load requirement against this document before purchasing one:
http://content.vexrobotics.com/vexpr...s-20150106.pdf
Watch out if you are planning on using a very low reduction with a CIM or a MiniCIM
Unread 16-03-2015, 22:30
Team 316 mentor
Depending on how much you want to lift you may need a stronger motor. We can reliably lift five totes without a can. If one wanted to lift heavier weights, adjustments would probably have to be made. As for performance. We did have a problem with the motor breaking. But we found that it was caused by our top limit switch malfunctioning. This caused the winch to constantly stall against the top of our elevator, which ruined the motor. Other than that the assembly has performed spectacularly.
Unread 16-03-2015, 23:15
AKA: Steve Peterson
You could also make a winch:
Unread 16-03-2015, 23:44
Originally Posted by Dale(294engr] View Post
144 / ~.1ohm 14.4 watts
1440 watts.
Unread 16-03-2015, 23:46
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Not too long ago there was a thread talking about dry ice and its legality. Maybe that might work well
Unread 17-03-2015, 01:34
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Only if you plan on using all of that load. We have a pretty fast elevator (1-2ft/sec) and we haven't run into load problems yet in the versaplanetary.
Unread 17-03-2015, 05:17
Attachment 18662
I love that idea! How hard was that to manufacture? How reliable is it?
Unread 17-03-2015, 09:02
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
Last year we cooled our CIM motors and Compressor with server rack blowers. They were considered legal, and worked amazingly well. You can put the KOP heatsinks on them for further cooling.
L.A.S.E.R - Light Amplification by the Stimulated Emission of Radiation
Unread 17-03-2015, 12:01
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Did you check the jumpers on your motor controllers? There is a jumper that lets the CIM freewheel (coast) or brake. Make sure you have the Motor Controllers in Brake mode. That will apply some counterforce, without having to power the motor. On our robot, brake mode is enough to keep the totes from dropping.
Unread 17-03-2015, 12:22
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Two CIMs should not be heating up during a match unless they are being very over-worked. Gear your mechanism more effectively to solve your real problem, don't address the symptom of over-heating motors.
Our 'totem' can support between 2 and 8 totes, plus the tote-grabbing bars, with a single stalled RS550 motor with no ill effects after two district events and lots of practice. We are using a 64:1 reduction with a 0.88in diameter spool to wind up cable.
Unread 17-03-2015, 12:52
AKA: Steve Peterson
It's built from:
AM-0145 Toughbox
AM-0396 long hex output shaft, cut down a bit
2 - AM-0069a 500 Hex hub, modded with set screws. One hub is also modded with teeth
2" of aluminum tube - 1.75" OD
Mini Cim
HS-422 servo
#10 threaded rod
3/4" x 1/2" aluminum bar as spacer for dog (has F <-> B in photo)
3/4" x .125" aluminum bar for dog
.090 servo support plate (sits between bar and the gearbox, holds the servo in position)
small qty of .090 polycarbonate to make dog actuator for servo
2 longer bolts (I think they're 1/4x20) for fastening spacer bar and plate to gearbox
#10 machine screw with washer for pivot. The spacer is tapped to accept the screw and there's one washer on the other side.
spring (random hardware store spring)
smaller machine screws (#6?) to fasten servo to servo support plate
It's probably 3-4 hours of work all together.
One key to longevity is to keep the dog from riding on the modded hex hub when the winch is operating. When we operate the winch in the lowering mode, we slightly raise it first before actuating the servo, so that the dog does not bind.
The only concern we have is that the winch is supported on only one side. We're bringing another gearbox plate and necessary hardware to make a support for the other side if that turns out to be a problem.
Unread 17-03-2015, 13:30
@OP: If you're willing, please tell us about your gearing. How many motor turns does it take to raise the boxes 1 foot?
