Go to Post Be the change you want to see. - staplemonx [more]
Unread 16-03-2015, 23:43
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Drive Team Fatigue
I was wondering what you guys did to prevent your drive team from becoming fatigued after a full 12 hour day of running back and forth across a high school. Any tricks or tips your team utilizes? For example, I've heard teams say good things (and some bad things) about Doctor Scholls.
Unread 16-03-2015, 23:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Drive Team Fatigue
High scooolers fatigued? I rarely let myself take that excuse on the high side of 50, though I do allow myself pollen as an excuse more often than I did in my twenties and thirties.
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Water and Gatorade all day, stay hydrated (I generally try to stay away from soda while at the competition). If you aren't required for any work in the pit or out at the practice field, take a break and watch some matches, or just sit down when you can. I feel you, it can be pretty exhausting.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 16-03-2015, 23:54
It gets a little worse in districts. Match turn around time is kind of nuts at some events.
Unread 16-03-2015, 23:57
philso philso is offline
FRC #2587
Try wearing foam earplugs. I find the high noise level at FRC events makes me feel tired. You might also find a quiet spot somewhere to relax. Of course, you should know your match schedule and other team members should know where to find you.
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Districts are very busy! I just drink tons of water and eat food whenever I can. And also do take breaks when you can...
Unread 17-03-2015, 00:01
Sam_Mills's Avatar
Sam_Mills Sam_Mills is offline
FRC #4965 (FIRE)
Sam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond reputeSam_Mills has a reputation beyond repute
When I drove we treated it as any other sport. We went to bed around 9-11 every night, ate clean, and drank lots of water. None of the "Pizza and Red Bull" diet you will often hear people brag about. We also split up the team so that we didn't have all 4 of our most competent students on the drive team. We had one drive team member who could program, but our other best programmer was in the pit, so that the drive team could recoup between matches.
If you have a mentor coach, this can be easy to enforce, but even with an all student drive team, mature driver quality students should be more than willing to take care of themselves to be at peak performance.
2013 MORT 11: Captain/Driver 60 - 19 - 1
2014-current FIRE 4965: Engineering Mentor
ewcp 2013-current
If you argue with math, you are going to lose.
Unread 17-03-2015, 00:03
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
This. Especially at Districts, drink and be full. Im the human player this year, and while i am accustomed to being tired, it takes a lot out of you, and this really does help.
Unread 17-03-2015, 00:14
April_robo's Avatar
April_robo April_robo is offline
AKA: April Sawyers
FRC #3548 (Robo Ravens)
April_robo is an unknown quantity at this point
I did way too much at competitions when I was the driver. I was always stressed out and thats what kept me going. But lots of water definitely helps. I also ate lots of fruits and veggies.
~3548 Alumni (2012-2014)~
~1188/3548 Mentor (2015-Current)~
Unread 17-03-2015, 00:20
Alyssa's Avatar
Alyssa Alyssa is offline
Everything in life should be MFD
AKA: Alyssa Vallese
FRC #0125 (NUTRONS)
Alyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond reputeAlyssa has a reputation beyond repute
Make sure that they're eating three meals a day and going to bed my 9pm after comp. Also, Vitamin C drinks are great.
Unread 17-03-2015, 00:33
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Oh where to start...
I'm our driver from last year and for this year. Last year at our second regional, I completely let myself go without knowing it. I ate near nothing, drank even less, and worked harder than I ever had before. The adrenaline kept me going through the competition, but I got home saturday night feeling great, after all we'd earned our ticket to champs, however come sunday morning my body refused to cooperate. I was severely dehydrated and couldn't move around the house. So after last year here's a couple of things I've come up with for this year:
Yes coffee tastes great, but you know what keeps you going longer than that burst of caffeine? A glass or two of water and a nice morning jog.
If something breaks in the match, well you tell the pit crew exactly what happens, that's what they are there for. Have faith, they are the almighty pit crew, they can and will fix everything. Go take a break, go for a jog, DRINK MORE WATER, watch a couple matches, talk to other teams, pit scout, talk to your scouters, engage the people in the stands. You are there to help your team succeed, everyone looks up to you, they will help you every way they can so return the favor and engage your teammates who are in the stands pulling those long scouting shifts.
For alliance selections, send someone else out. Let the drive team weigh their opinions in before hand and then send them to the stands or to go eat lunch during the selections. They're going to spend the rest of the break strategizing with their new partners, no time to eat then.
Most importantly, eat a filling dinner, do whatever strategy talks you need to with scouters and such, and then straight to bed. Drive team needs the sleep.
tl;dr: LOTS OF WATER, whatever your contribution in the pit is, someone else can do it better. Eat food whenever possible. And sleep, lots of sleep.
Unread 17-03-2015, 00:37
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
You don't know fatigued until you pushed your robot, cart (that had a bad steering wheel...), and driver station outside, up a two story ramp, then back inside just to get to the practice field. Oh, Sacramento Regional....
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 17-03-2015, 07:04
Gdeaver Gdeaver is offline
FRC #1640
Sleep banking and hydration are very important. At HH I noticed our drive team wearing down the last 2 matches of day one. They need to address this for the next competition.
Unread 17-03-2015, 08:01
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I know from my experience in FTC as a driver that it definitely helps to stay hydrated and get like lots of sleep, but it also helps to keep your cool in any situation. Getting stressed out about a foul/penalty/robot breaking will only strain you more. If you are stressing out, just remove yourself from the situation, go talk to the scouters, or just watch a few matches.
Unread 17-03-2015, 08:12
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
If you're anything like me then you won't get tired until the event ends because the adrenaline of the event keeps you pumped up, but staying hydrated is key.
Our drive team always has a bottle of water with us and often we go up to the stands and watch matches between ours as the stands are so close(regionals, not districts I guess)
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
