Go to Post I like this thread because it means I don't have to leave my house to find something to complain about! - PayneTrain [more]
Unread 15-03-2015, 15:27
brobotics5162 brobotics5162 is offline
FRC #5162
brobotics5162 is an unknown quantity at this point
Exclamation Need 1/2 in key banebot wheels!
Our team was working on an intake mechanism as of our 30 lbs. All of the wheels we tried were too hard and would either not grip the tote or start to cut the sides, so we decided to bail on the mechanism. It was very apparent at our competition that we would be needing that mechanism at our next event. On some advice from another team I looked into green/orange banebots wheels. However, the gearboxes we currently have are 1/2 in key shafts and I cannot find anywhere online. So I am looking for someone who would be willing to sell us green or orange banebot wheels of any size as long as they are 1/2 in key mount.
Unread 15-03-2015, 15:34
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Need 1/2 in key banebot wheels!
So you are looking for something like this?
http://banebots.com/pc/WHB-KS4-498/T80P-494BO-KS4
Also if you have a picture of the gearbox we may be able to help you find it from the picture.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-03-2015, 15:45
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
We ran into the same issue with our intake late in the season. Banebot has nothing in stock and has no urgency in getting more of them in stock. A couple alternatives we found to work:
Hubbed colson wheels from vex pro. Unmodified, they were okay, but cutting/melting grooves in a pattern greatly improved their grippyness.
We ended up using vex versa wheels with a rubber cylinder glued onto the outside of it. I can get more info on it if you want. We were even getting better results than with the banebot wheels.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 16-03-2015, 15:01
FRC #5162
The vex wheels sound like a viable alternative. What kind of rubber cylinder did you use?
Unread 17-03-2015, 09:27
Toolman Toolman is offline
Coach
AKA: Tony
FRC #3171 (WHB/Hurricanes)
Toolman is an unknown quantity at this point
Lightbulb Re: Need 1/2 in key banebot wheels!
Some options when you have two sized keys on the same shaft.
option 1- broach the existing pulley/gear to 1/2" if you have a broach.
option 2- order what is called a step key which will have two sizes in one key. (MMC) can usually get it to you within 48 hours or less.
option3- get a 1/2" key and machine the other side to the size you need thus making your own step key.
PS: Are you sure it is a 1/2 inch key this is a very big key for a large shaft usually for much bigger shafting ?
Unread 17-03-2015, 09:40
avanboekel's Avatar
It was polyurethane tubing we got off of McMaster. I believe we had the ID a bit under the size of the wheel so it kinda compressed onto the wheel a bit. We held it in place with epoxy. You can see them in action in the first video linked on this page. http://www.chiefdelphi.com/forums/sh...hreadid=135857
Unread 17-03-2015, 11:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I am reading that as 1/2 D shaft with what would generally be a 1/8" key.
You can get a broach & bushing from McMasterCarr, MSC, etc. You really need an arbor press or equivalent to use it though. Broaches are brittle & do not like side loading
Unread 17-03-2015, 11:39
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
VexPro Versa hubs can come with a 1/2in key drive, as do several AndyMark hubs. Either of these hubs will connect to numerous FRC-type wheels that you can cover in whatever tread makes you happiest.
