Go to Post So once and a while no matter how addicted you may be, try to think outside the 48'x24' box of FIRST. - Tytus Gerrish [more]
Unread 17-03-2015, 09:50
Re: RoboRIO / FMS / mDNS / lessons learned
Here's an example of the PDP fuses working their way out by the time eliminations rolled around.
They were never pushed in all the way.
Properly inserted there should only be about 1/4" showing, and are not removable by hand any longer.
If you can easily remove the fuses by hand, then they are not seated all the way.
Attached are three variations:
- fuses on a robot in Semi-Finals that have worked their way out
- fuses properly seated
- one good/one badly seated fuse to compare
ID:	18665  Click image for larger version
ID:	18666  Click image for larger version
