Go to Post I wonder if it could be... Nah, that would just be way too... Never mind. . - dlavery [more]
Unread 17-03-2015, 11:07
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Smile Turning LEDs on with a spike while disabled
Is it possible to do that?
I would like to check if the vision processing works through the dashboard before the match starts, but I would like to turn them off while not in autonomous.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 17-03-2015, 11:08
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Turning LEDs on with a spike while disabled
I don't believe this is possible since all actuators are turned off while disabled.
Unread 17-03-2015, 11:27
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
In the past we have been connecting LEDs (monochromatic, ring type) to PD directly and it stays on as long as power is turned on. Once dashboard is connected to FMS, the camera feed will be available.
Unread 17-03-2015, 11:32
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
If you really need to be able to turn them on and off, you can make a simple circuit with a transistor and use a digital output to control it.
Unread 17-03-2015, 12:05
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
You could use addressable LEDs, and control them with an Arduino. The RoboRIO can output information to different input pins in the Arduino, and use those combinations to set the information sent to the LEDs.
Example:
If no pins receive input, set LEDs to X (Thats Disabled)
If pin 1 receives input set LEDs to Y
If pin 2 receives input set LEDs to Z
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 17-03-2015, 19:24
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Example:
You can use any number of output devices to control the lights as part of your custom circuits as long as you are not controlling motors, solenoids, or other actuators I think you are fine.
All you need is a way to get information out of the RoboRIO to the control device and some sort of circuit to turn the lights on/off.
There are tons of ways to get data into or out of the RoboRIO (I2C, UART, SPI, Ethernet, USB, ...) and there are an even larger array of choices for ways to turn the LEDs on/off
Dr. Joe J.
Team #88, TJ2
Unread 17-03-2015, 23:17
AKA: Josh Patterson
Yeah, with SPI output on the RoboRIO, You might be able to eliminate any other circuit or device. I believe you can get LEDs that can be controlled by just SPI.
2016-Present FTAA
