Go to Post *quick grab the epoxy we can rebuild him, make him stronger than before* - amos229 [more]
Unread 17-03-2015, 15:30
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
Re: Why isn't my slowdown working?
Originally Posted by 414cnewq View Post
Well, there's another portion of my code affected by the slowdown (the tote pickup motor) that is affected by the slowdown:
outside TeleopPeriodic:
float motorpower;
inside:
if(stick->GetRawButton(10))
motorpower=0.4;
else
motorpower=1;
later in TeleopPeriodic(where vmc is a talon object):
vmc->Set(motorpower);
and that does not work.
any thoughts?
What I mean by it doesn't work is that the motor doesn't slow down. It keeps at the same speed.
Unread 17-03-2015, 21:52
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Are you sure you're pushing "Button #10"?
