Go to Post I trust in Martus. - Petey [more]
Unread 15-03-2015, 09:45
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Arduino - RoboRIO Question
We've created an Arduino based indicator that we want to use, which gets triggered by the relay signal that is sent to a Spike. (One action is activated when the motor is run in one direction, and a different action is activated when the motor is run the other direction. A third "neutral" action runs when the motor is not engaged.)
Before installing, we measured the voltage of the red and white PWM wire leads (with respect to the black) and found them to be very close to +5v (for each direction the motor is run, respectively).
Using the 5V supply from the Arduino itself to simulate the voltage from the PWM wire signals, the program worked perfectly off the robot.
When we put the indicator on the robot, it remained in the "neutral" third action no matter what we did with the motor. When we checked the voltage again (white and red from PWM WRT black), we found it to be now only approximately 1 volt.
So I guess my questions (finally) are (1) Why does the voltage read 5 Volts when not attached, and only 1 Volt when attached...and (2) Is this normal or have we done something wrong. Then (3) If this is normal, we can use an analog input...what minimum voltage should we expect at each signal pin, so we know what to use as our "trigger" value?
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 15-03-2015, 10:19
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Arduino - RoboRIO Question
Without a circuit diagram it sounds like you are overloading something.
How much current does your circuit input draw when it works correctly?
Unread 15-03-2015, 10:29
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
I haven't measured, but it is only a bunch of LED's and they should be independently powered by the Arduino, which we have plugged into a 12V supply from the new VRM.
Without a circuit diagram, I'll try to explain...eight groups of LED's are wired to the digital pins 6-13 - configured as outputs (anodes) and to ground (cathodes). Red PWM wire to pin 1 (configured as input) and White PWM wire to pin 2 (also input). Black PWM wire to ground.
Program runs only as if there is no voltage on either of the red or white PWM wires...however the robot works perfectly - motor goes forward and reverse exactly as controlled. When we checked the red and white wire voltage with everything connected, the voltage was much lower than the 5V we expected.
Unread 15-03-2015, 10:47
techhelpbb's Avatar
What motor are you describing?
Unread 15-03-2015, 10:54
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
We have split the PWM going to our lift motor's relay...the cable now simultaneously controls the Spike, and thus the lift motor...and is input for the indicator LED apparatus through the Arduino.
The motor is still responding, though the Arduino is not receiving a sufficient voltage to activate the indicator action.
Unread 15-03-2015, 11:06
techhelpbb's Avatar
Try disconnecting the split and just driving the Arduino.
Make sure to check the voltages before you hook up just the Arduino.
Unread 15-03-2015, 11:34
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Without a circuit diagram, I can only make suggestions that are nothing more than a guess.
That said, the first thing I would suggest is making certain that you are also tying ground from the RoboRio to the ground on the Arduino.
The next step I would do would be to put 10k ohm pull down resistors on the inputs to the Arduino. That would make sure that you have a solid ground reference, and not have the inputs to the Arduino floating.
Unread 15-03-2015, 11:43
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
We have the black (ground) wire from the Spike's PWM going to ground on the Arduino...is that sufficient for grounding the RoboRIO to the Arduino as suggested...and for the pulldown resistors, do I just wire the red and white each through a 10K to ground? I did have it that way on the "off-board" but eliminated the resistors when I went to the robot.
Unread 15-03-2015, 12:34
billbo911's Avatar
Yes and yes. Additionally, don't define the inputs on the Arduino as "Input Pullup". That would negate the action of the pull downs.
Unread 15-03-2015, 13:41
[Disclaimer: I cannot find a schematic to the Spike internals. What I say here is from many-years-old memory and not guaranteed.]
The Spike inputs are not logic level signals. They actually provide power to an optical isolator. The current is supposed to be limited to 40 ma; I do not know what voltage that ends up corresponding to.
The roboRIO Relay outputs have a 40k resistor to ground, so there is no need for a pulldown on the Arduino inputs.
Unread 15-03-2015, 13:57
billbo911's Avatar
True. I was not aware of the internal pull-down resistors.
Unread 15-03-2015, 22:06
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
I would probably connect the Arduino to a digital output from the robotRio and just have the program control the digital outputs wherever its controlling the spike.
Brian K
Team 1225 Robotics Mentor
Unread 17-03-2015, 18:30
techhelpbb's Avatar
Much like your I/O issue you've left this topic in an indeterminate state
So did you figure the issue out?
Unread 17-03-2015, 22:35
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Actually, no. I though I had something with the resistor to ground suggestion, then Alan pointed out that there is already a large resistance in the relay outputs to ground. SuperBK's suggestion is a good one, but programming is not our strength this season, so I don't want to ask the programmers to add any complexity at all. I wrote an Arduino program that uses the analog inputs, and a while loop for greater than ... I'll try that. It should be able to detect the very low voltage we are reading. Otherwise, we'll just run a decorative program. Thanks, though!
(SuperBK is a recent acquaintance...and will be at the NC Regional with us on Thursday...perhaps I'll monopolize some more of his time!)
Unread 18-03-2015, 10:21
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
AFAIK the red pwm wire is 5v and not a data line.
