Go to Post If you think that teams would never bypass the rules or do something unsafe (intentional or unintentional), I suggest you spend a weekend as an inspector. Every bad scenario that you can think of, we have seen. - Al Skierkiewicz [more]
Unread 17-03-2015, 17:44
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Using the old cRIO control system
Folks,
My team has a number of the cRIO control systems, as well as a couple of robots that we would like to get active again for off season projects.
When the roboRIO was announced it was advertised that teams could still use the old control system for development/testing using the new programming framework.
Therefore the question becomes, now that we have had most of the season (build + competition) behind us, has anyone found a way to program the older components using the new programming components? This is besides trying to find and load all of the old programming software and run it like previous years.
Thanks.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 17-03-2015, 17:53
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
Re: Using the old cRIO control system
If you're talking about LabVIEW, then it's perfectly possible. I've programmed a test board using the 4-slot cRIO II, DIO breakout, etc using the newest version of LabVIEW (albeit in a cRIO project, not a roboRIO one). There is an option to create a cRIO project to work with it.
However, 8-slot cRIOs cannot be programmed with LabVIEW 2014 and must be programmed with 2013.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 17-03-2015, 18:06
feverittm's Avatar
I should have included that we use Java.
Thanks
Floyd Moore
Unread 17-03-2015, 18:12
Ben Wolsieffer Ben Wolsieffer is online now
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
With Java, you have to use the the 2014 frameworks.
Unread 17-03-2015, 19:09
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
If you want C++ check this link:
https://usfirst.collab.net/sf/projec..._crio_c_tools/
-Hugh
Unread 18-03-2015, 07:50
elfenari elfenari is offline
1099 Discotechs Captain
AKA: Ari Elfenbein
FRC #1099 (Discotechs)
elfenari is an unknown quantity at this point
We were playing around with this for the same reason as you guys (Java team). The programming must still be done in netbeans with the old plugins because of the way the IDE sends code to the controller ( unless someone can make a plugin for eclipse that doesn't use the mDNS the roboRIO uses). For driving, if you have a 4-slot cRIO, you should be able to flash the latest image (73? 43?) and use the 2015 driver station by selecting 2009-2014 from the control system menu. If you have and 8-slot, like we do, it doesn't support the latest firmware. Our solution was to reimage an old classmate with last years software, and just drive with the old driver station.
Unread 18-03-2015, 08:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
From another thread:
Originally Posted by Jacob Bendicksen View Post
  • Yes, you'll need to use the roboRIO if you're using WPILib Java. However, if you use the CCRE, our custom Java runtime engine that our awesome software manager Colby built, the code is identical. Not sure if you're interested in using it, but it would make it possible to write code that runs on both the cRIO and the roboRIO.
