Go to Post .. if everybody else is buying all the thingamabobs so they can practice shoving balls into the whatsit. Maybe what you really want is to buy thingys so you can build a practice whojidingle. Being the only whojidingle robot can be a real advantage come alliance picking time ... - ChrisH [more]
Unread 03-12-2015, 03:44 PM
414cnewq 414cnewq is offline
FRC #3844 (Kentucky Wildbots)
414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of414cnewq has much to be proud of
Why isn't my slowdown working?
Okay. I have this code to add joystick sensitivity(it seems to work):
void joystickSanatizer(float*x, float*y){
//Pointers All the Way!!! #starmaster
if(*x<0){
*x*=*x;
*x*=0-1;
else *x*=*x;
if(*y<0){
*y*=*y;
*y*=0-1;
else *y*=*y;
in TeleopPeriodic:
float joyx=stick->GetRawAxis(0);
float joyy=stick->GetRawAxis(1);
joystickSanatizer(&joyx, &joyy);
if(stick->GetRawButton(10)){
multiplier=0.4;
else multiplier=1;
and then, after some unrelated code:
rBot->ArcadeDrive(joyy*multiplier, joyx*multiplier);
Where stick is an XBox 360 controller and rBot is a a RobotDrive object
The point of this code is to slow down the robot... but it doesn't.
Can someone help me fix this code or give me another way to slow down the robot.
Unread 03-12-2015, 04:12 PM
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Why isn't my slowdown working?
Have you added debug print statements for you code to see if your inputs and outputs make sense?
THat might help you get a quick sanity check of where your code is going wrong.
Is there's a reason you don't want to do something a little simpler?
float joyx = stick->GetRawAxis(0);
float joyy = stick->GetRawAxis(1);
  multiplier = 0.4;
} else {
  multiplier = 1;
rBot->ArcadeDrive(joyy * multiplier, joyx * multiplier);
Just change your multiplier variable to affect commanded rate of travel.
It doesn't give you X^2 scaling, but not sure you need that.
Keeping the x^2 implementation:
//#nostarmaster
joyx = joyx * abs(joyx);
joyy = joyy * abs(joyy);
  multiplier = 0.4;
} else {
  multiplier = 1;
I think this one does exactly what you were trying to do in your code.
http://team2168.org
Last edited by otherguy : 03-12-2015 at 05:22 PM. Reason: added another option closer to original implementation
Unread 03-12-2015, 05:24 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Or even simpler, with squaring:
multiplier = stick->GetRawButton(10) ? 0.4 : 1;
rBot->ArcadeDrive(joyy*abs(joyy)*multiplier, joyx*abs(joyx)*multiplier);
Unread 03-12-2015, 05:53 PM
Well, there's another portion of my code affected by the slowdown (the tote pickup motor) that is affected by the slowdown:
outside TeleopPeriodic:
float motorpower;
inside:
motorpower=0.4;
else
motorpower=1;
later in TeleopPeriodic(where vmc is a talon object):
vmc->Set(motorpower);
and that does not work.
any thoughts?
Unread 03-12-2015, 11:40 PM
otherguy's Avatar
sparkE
AKA: James
Can you share an actual excerpt from your code?
Can you elaborate on "doesn't work"? What action are you performing and how is the robot responding that leads you to the conclusion that it's not doing what you want?
The 'code' looks reasonable, but you haven't really described what is happening, just that what happened isn't want you expected.
http://team2168.org
Unread 03-17-2015, 03:30 PM
float motorpower;
inside:
motorpower=0.4;
else
motorpower=1;
any thoughts?
What I mean by it doesn't work is that the motor doesn't slow down. It keeps at the same speed.
Unread 03-17-2015, 09:52 PM
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Are you sure you're pushing "Button #10"?
