Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 17-03-2015, 22:12
robot robot is offline
robot is an unknown quantity at this point
[FTC]: VEX PRO Mecanum Wheels mounted on tetrix axles?
We recently purchased a double set of vex pro mecanum wheels ( http://www.vexrobotics.com/mecanum-wheels.html ) with http://www.vexrobotics.com/217-3255.html , and we have no idea how we can mount them onto a tetrix bot.. Anyone have any experience with these wheels?
Unread 17-03-2015, 22:29
JimInNJ JimInNJ is offline
AKA: Jim Bates
FTC #9765
JimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond reputeJimInNJ has a reputation beyond repute
Re: [FTC]: VEX PRO Mecanum Wheels mounted on tetrix axles?
Got access to a 3d printer?
http://www.thingiverse.com/search?q=vex+mecanum&sa=
Unread 17-03-2015, 23:00
Owen Busler's Avatar
Owen Busler Owen Busler is online now
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
My team has a 3D printer and we could ship a few of them to you. DM Me if you are interested.
Unread 18-03-2015, 07:39
The problem is that there are 2 different 4'' mecanum wheels that vex sells. (http://www.vexrobotics.com/276-1447.html and http://www.vexrobotics.com/mecanum-wheels.html, we own the latter). This means that there is a chance that these models will not work with our wheels, and none of the descriptions specify.
Unread 18-03-2015, 09:31
REVving up for a new season
FRC #2848 (All-sparks)
http://www.andymark.com/product-p/am-2609.htm
This part is what you need. All the larger wheels made by AndyMark and vex both use a 1.875 bolt hole circle for attaching sprockets and gears. The plate I linked to has the right hole pattern to bolt to your vex wheels and the center is setup for one of the standard tetrix hubs. You could easily make this part if purchasing is not an option.
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 18-03-2015, 09:57
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Greg
This won't work for the 4" Vexpro mecanum wheels, they are the odd ones out since they're so tiny. The drawing shows their bolt circle to be 1.125". http://content.vexrobotics.com/vexpr...g-20140926.PDF
You could drill a set of holes in the AM adapter plate that match the Vexpro wheel bolt circle, but getting them concentric with the axle would be a little bit tricky.
Unread 18-03-2015, 10:36
Thumbs down Re: [FTC]: VEX PRO Mecanum Wheels mounted on tetrix axles?
Maybe I could design an adapter to the vex axle that acts as an axle hub by forming the shape of a tetrix axle (round but flat on top) , that way the wheel would turn with the axle....no need to mod the wheel or screw anything into it
Unread 18-03-2015, 11:13
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
For future reference, these are cheaper and mount directly to the tetrix hub.
http://www.andymark.com/product-p/am-2626.htm
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 18-03-2015, 11:51
we have heard of many issues with these wheels, which is why we chose not to use them. Also they only support 17 lbs, which might not be enough for our bot.
Unread 18-03-2015, 13:38
budman budman is offline
FTC #9010 (Robotic Rangers)
budman is an unknown quantity at this point
The shaft on a Tetrix or Andymark NeverRest motor is 6mm. So need to get from 6mm to 1/2" hex for the Mecanum wheels you mentioned. Since the wheels are so wide (2.25"), I would recommend the really cool ThunderHex shafts from Vex Robotics. You could cut to the desired length, enlarge one end with a 6mm drill bit to fit on the motor, then drill/tap two holes for set screw. The wheels can be held on the shaft with Vex Robotics 1/2 hex clamping collars.
We built some shafts and drill/tapped with 8/32 and used the HeliCoil inserts to make sure they were strong. Never had a problem all season! Here is a link to the HeliCoil inserts we purchased on Amazon.
Unread 18-03-2015, 13:50
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
17 pounds per wheel not total.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 18-03-2015, 14:20
ftelliott ftelliott is offline
Sunset High School Head Coach
AKA: Friedrich Elliott
FTC #8811 (RoBo Bison)
ftelliott is an unknown quantity at this point
Might these work?
http://banebots.com/pc/WHB-HS-M6/T40H-SM61
Unread 18-03-2015, 15:23
In my option, they would be a little short for the 2.5" width of the Mecanum wheels.
The "3 wide" ones would work better.
http://banebots.com/pc/WHB-HM-HS4-M6/T40H-SM63
These are only about 1.5" wide, so will not go all the way through the 2.5" wide Mecanum wheel. Could test and see if would work.
Unread 18-03-2015, 20:38
hmm... perhaps.. a bit pricey. $28 with shipping for 4 of them.. May be my only option, though. Surely other teams have used these wheels though.
Unread 19-03-2015, 10:52
Send me a PM with your address and I will send you a working sample of the ThunderHex.
