Trouble with serial port: HAL - VISA: Resource Not Found
Greetings, we hare having trouble using our NavX MXP via its USB connection.
We have our NavX connected using a USB cable as described: https://code.google.com/p/navxmxp/wi..._via_USB_cable When running the sample code https://code.google.com/p/navxmxp/so...eRobotExample/ We get the following exception: Code:
ERROR Unhandled exception: java.lang.NullPointerException at [ org.usfirst.frc.team2465.robot.Robot.operatorControl(Robot.java:93), edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:148), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:234)] Code:
boolean is_calibrating = imu.isCalibrating(); We moved the following line of code into the robotInit method yields a more descriptive error: (Robot.java:81) Code:
SerialPort my_serial_port = new SerialPort(57600,SerialPort.Port.kUSB); Code:
ERROR Unhandled exception: java.lang.RuntimeException: Code: -1073807343. HAL - VISA: Resource Not Found at [ edu.wpi.first.wpilibj.hal.HALUtil.checkStatus(HALUtil.java:48), edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:198), edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:251), org.usfirst.frc.team2465.robot.Robot.robotInit(Robot.java:81), edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:121), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:234)] |
Re: Trouble with serial port: HAL - VISA: Resource Not Found
If you are using the USB serial port, make sure that the RoboRio is actually recognizing the port, by using the web dashboard. There's more info about how to ensure the binding is working correctly on the nav6 Troubleshooting page.
