Go to Post I think another really awsome thing about FIRST can be summed up by what Dan, the Wildstang operator, said when they won nats: "I built that!" I mean, the feeling of satisfaction you get knowing that something you created can perform such unbelievable tasks is amazing. - Jupee [more]
Thread Tools Rating: Thread Rating: 47 votes, 5.00 average. Display Modes
Unread 18-03-2015, 19:49
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Got Gyro drift? Try Sensor Fusion !
So.. Loving the ADAIMU code. Thanks.
Have a problem. If the robot is being moved during startup, the Gyro gets a bad cal.
I see where you make two attempts, but the problem could last longer then that, and I'd realy prefer not to hold up the begin code too long.
I put a filter on the angular rate and check it in Disabled.vi
If it get too large (more than 0.1) I want to do a recal.
Easy with the analog gyro.... Can't figure how to do it with your IMU code
I tried just redoing the open... it failed, looks like coms doesn't like two opens.
There doesn't seem to be an IMUclose.vi
What is the best way to initiate a re-cal, or restart of the IMU?
Don't need a recal on the magnetics, just the gyro.
Phil.
Phil Malone
http://www.GEARSinc.org
