Go to Post It shouldn’t be about whether or not you think it’s easy or not, it’s about whether or not you think the effect of the change would be a positive step for our country. - Bill Gold [more]
Unread 19-03-2015, 22:25
Mattpenguin Mattpenguin is offline
AKA: Matthew Roberts
FRC #4265 (Secret City Wildbots)
Mattpenguin is an unknown quantity at this point
Competition Tethering Issue
Our team is competing at the Bayou regional, and we began having strange connection issues towards the end of the day after we connected to the field. We connected to the feild fine, and returned to the pit to push a new version of code, which was also successful. Later, we went to the particle field and we were unable to get commms with the Driver Station, however we were able to ping the D-link, ping the roboRIO, and push code perfectly fine, we were just unable to get any sort of communication via the DS. We tried multiple Ethernet Cables, rebooting the robot, and setting static IP's on the driver laptop. Any help would be greatly appreciated, and if any more information or clarification is need feel free to let me know
Unread 19-03-2015, 22:31
randantor randantor is offline
AKA: James Y
FRC #0624 (CRyptonite)
randantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of light
Re: Competition Tethering Issue
Did you try restarting the driver station? We've found that when transitioning between tethered operation and the field we need to restart both the robot and the driver station exe to reliably get a connection.
Another thing to try, which can help when things sometimes just stop working, is to restart the NI mDNS Responder Service from the Services menu in the Windows control panel.
Unread 19-03-2015, 22:36
We did try restarting the driver station, but we will try restarting that service later if nothing else seems to help.
Unread 19-03-2015, 22:59
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
A quick way to refresh mDNS is to change the team number in the driver station software to some other number (ex. 1) and then change it back to your team number.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 19-03-2015, 23:07
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
ping the robot and/or flush the arp cache, that worked for us
Unread 26-03-2015, 19:03
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
You could also try the USB tether
Unread 26-03-2015, 21:53
Jared's Avatar
Jared Jared is offline
You can try enabling/disabling the network adapter.
Unread 27-03-2015, 10:53
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Another thing to try is to reboot the DS between tethering and competition.
When at the practice field, if we were very patient then things eventually connect with no intervention other than DS software restart.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
