Go to Post Man, FIRST is amazing :D - galewind [more]
Unread 19-03-2015, 21:32
JackCostello JackCostello is offline
FRC #4499
JackCostello is an unknown quantity at this point
Strange Driver Station Logg
My team have recently been seeing a strange log output for our driver station. It looks like a binary file since it is a series of unicode characters, but we can't figure out where it comes from. The attached file is a screenshot of one such output. The exact characters are not the same each time. We are using Windows 7 64 bit, and programming in Lua, which is built on C. Does anyone know what is happening here? It doesn't seem to have actually caused any problem, but it looks very much like it will in the future and in any case we want to know what is happening on our systems whenever we can.
Unread 19-03-2015, 21:40
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Strange Driver Station Logg
No idea what the cause is, but we've seen very similar output using java.
Unread 20-03-2015, 00:08
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Is there a procedure to reproduce this? I would like to investigate this. Maybe file a tracker at https://usfirst.collab.net/sf/tracke...cker.4_defects
Unread 20-03-2015, 00:13
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
This started happening to us after we installed the latest WPILib(C++) update and updated the firmware on all our devices (RoboRio, PDP, PCM, Talon SRXs).
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 20-03-2015, 14:29
If you could contact me and provide the log file, both .dslog and .dsevent, that would help me to look into it. I have seen this once, but do not know how to reproduce it and don't know what may be causing it.
Greg McKaskle
Unread 20-03-2015, 14:43
Jared Russell's Avatar
Taking a year (mostly) off
We have seen this several times on our Driver Station. We use Java.
We had assumed that it was just the Great Cthulhu trying to speak to us.
Unread 20-03-2015, 16:51
FRC #4499
Some of you are saying you are also seeing this with Java. Is anyone getting this with C++ as well? We'll try to figure out the procedure to replicate this.
Unread 20-03-2015, 17:00
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I'm sure Cthulhu has mastered UTF-8
no stranger to the working end of a pencil
Unread 20-03-2015, 17:06
randantor randantor is offline
AKA: James Y
FRC #0624 (CRyptonite)
randantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of light
Not C++, but we use LabVIEW and we see it every so often. It seems to happen sometimes after the robot has been connected for a while.
Unread 20-03-2015, 19:38
While Cthulhu may or may not know UTF-8, this is a binary string that is supposed to be logged to the .pdplog file. It contains integers and bitfields and is being transmitted via TCP alongside the error messages. The parsing or construction of the info seems to get off and this is treated like an error message ... and that is where the odd characters come from. No Ouija, no Cthulhu.
Greg McKaskle
Unread 21-03-2015, 01:31
I have logs of the same occurrence from week 1 when it happened to Team 359.
I'll send them when I get home from my current volunteer gig.
Unread 21-03-2015, 15:31
FRC #4499
Has anyone actually had any issues stemming from this? It has been harmless for us so far, and if no one has actually had any issues it could just be a simple mis-directed or mis-parsed file. I don't want to waste anyone's time trying to solve a non-issue. However if someone actually has had problems with this I would like to help fix it.
Unread 21-03-2015, 16:57
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
We had this happen at least once while setting up on the field at GTRC. We also use Java. It didn't seem to have any negative effect on our robot.
In life, what you give, you keep. What you fail to give, you lose forever...
