Go to Post Repeat after me: "The Internet is my friend." :rolleyes: - Bill Moore [more]
Unread 17-03-2015, 09:38
lalondma lalondma is offline
AKA: Marc Lalonde
FRC #3990 (Tech for Kids)
Rookie Year: 2015
lalondma is an unknown quantity at this point
Default working directory for FRCUserProgram process?
Hello,
Recently, I got a program crash because the text file that was supposed to be loaded by AutomonousInit (C++ - iterative robot) could not be found. The file was placed in /home/lvuser alongside the binary FRCUserProgram, so I expected a call like fopen("foo.txt","r") to work but it didn't. fopen("/home/lvuser/foo.txt","r") did work however, so it's not a permission issue. Also tried to put the file in "/home/admin" in case FRCUserProgram would run as admin, without success. Anybody knows what the default working directory is? "/", maybe?
Unread 17-03-2015, 12:59
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Default working directory for FRCUserProgram process?
http://linux.die.net/man/3/getcwd
Test and share results?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 18-03-2015, 17:53
AKA: Marc Lalonde
Rookie Year: 2015
Indeed, got it with getcwd (thanks for the tip):
/usr/local/natinst/labview
Not especially intuitive...
Unread 19-03-2015, 23:46
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Sorry about that. I'll fix it for next season if you'll file a tracker at https://usfirst.collab.net/sf/tracke...cker.4_defects
Unread 20-03-2015, 00:10
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
We ran into a similar issue. Our findings indicated that the working directory was different when running while debugging and running when deployed. The quick fix for us was to use the entire path: /home/lvuser/Encoder_Offsets.txt.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
