Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 20-03-2015, 23:53
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
ITG 3200 I2C Gyro help
We are trying to use this sensor:https://www.sparkfun.com/products/11977
Ive managed to get numbers from the sensor but nothing usable. Any help would be greatly appreciated.
Heres what i have so far:
Begin VI:
Periodic Tasks:
Custom VI:
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
Unread 21-03-2015, 00:56
randantor randantor is offline
AKA: James Y
FRC #0624 (CRyptonite)
randantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of lightrandantor is a glorious beacon of light
Re: ITG 3200 I2C Gyro help
We tested the SparkFun 6 DoF IMU during build season, which contains an ITG-3200 during build season and read it successfully with this code:
I think you have the high and low byte of each register swapped. According to the datasheet the first byte (lower address) of each register is the MSB.
Also, we used the cast function rather than the conversion function to get a signed int. I'm not sure if that actually results in different values, but casting the value worked for us.
Good luck! The ITG-3200 worked pretty well for us as an improvement over the KOP analog gyro, with the signal not being susceptible to the effects of mysterious static buildup at inopportune moments...
Unread 21-03-2015, 11:02
FRC #0228 (Gus)
Can you please post how you send the setup values for the Gyro.
Thanks,
Also if you want to add me on Facebook to get back to each other faster:
https://www.facebook.com/MattSmith228
2015-2016 CSA
Facebook
