Go to Post I'm in it for the challenge, winning is just a side effect... - davidthefat [more]
Unread 21-03-2015, 14:49
L1TH1UM L1TH1UM is offline
FRC #4334
Rookie Year: 2015
L1TH1UM is an unknown quantity at this point
Preferences table Null Pointer Exception
Hello,
We are having some issues using the preferences table utility on SmartDashboard. We are supposed to be getting a table from which we can edit robot preferences such as potentiometer setpoints and encoder setpoints.
However, when we run the code it throws a Null Pointer Exception because we declared the preferences varable (Preferences prefs but we didn't create and object and we are trying to use an operator (prefs.getDouble). Using "prefs = new Preferences();" does not work, and there's nothing on the wpilibj documentation that tells us how to fix this (create an object for preferences).
Here's the page we're referencing: https://wpilib.screenstepslive.com/s...smartdashboard
Our code is almost exactly the same as that just minor differences such as names and values. We are programming in Java.
Any help would be appreciated, thanks.
Unread 21-03-2015, 15:27
Re: Preferences table Null Pointer Exception
The sample on that page seems to be missing a line:
prefs = Preferences.getInstance();
Unread 21-03-2015, 21:33
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
You're right! Thats quite funny. Here's the actual code for reference
package org.usfirst.frc.team40.robot;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Preferences;
public class Robot extends SampleRobot{
    Preferences prefs;
    double armUpPosition;
    double armDownPosition;
    public void robotInit(){
        armUpPosition = prefs.getDouble("ArmUpPosition", 1.0);
        armDownPosition = prefs.getDouble("ArmDownPosition", 4.0);
On a side note, to follow NetworkTable conventions the method name should be "getNumber" but that is trivial.
Unread 22-03-2015, 00:05
FRC #4334
Rookie Year: 2015
Thank you, I appreciate it. This fixed our problem.
Unread 22-03-2015, 10:57
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
If you didn't do so already, please use the form on the page to report the error.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
