Go to Post A stack is a stack is a stack. (How Profound!) - Paul Copioli [more]
Unread 21-03-2015, 18:29
ROULT ROULT is offline
AKA: pepemanboy
FRC #4403 (ROULT)
ROULT is an unknown quantity at this point
RAMP TETHER
After watching Waterloo, I've seen many ramps...
Why is Simbotics not tethered to its ramp?
Is it legal not to be tethered to a ramp?
Unread 21-03-2015, 18:46
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Re: RAMP TETHER
Their 2nd pick (5719) I am sure was very light and as such passed inspection with both ramps as tethers. That's why you'll see them sitting by the back ramp for the whole match.
Unread 21-03-2015, 19:02
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: RAMP TETHER
We did the same in our quarterfinals at waterloo - during eliminations, we had an alliance member assume our ramp tether (we were planning on adding an autonomous canburglar which would prevent the tethering, but didn't finish it in time).
You need to make sure the new ramp owner puts their team numbers on the ramp since it becomes part of their robot, and gets re-inspected for weight/transport config.
I will say it was wonderful to have the robot driving around without having to worry about the rope/tether.
Unread 21-03-2015, 20:42
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
Re: RAMP TETHER
At tech valley after we build our ramp and had or only weigh 3 pounds with our initial tether many teams copied the initial design to make super light weight ones. By today at least 5 or 6 teams more has tethers then the inital 3.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 21-03-2015, 20:45
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: RAMP TETHER
Week 4 - The Week of the Tether!
I was at Great Lakes Bay Regional. At inspection, 314 brought in their ramp (which had the ironic string tether). By the end of the competition, nearly 5 teams had built their own tethers, including their elim partner 2619 and the kettering team 1506.
We'll see what the game manual revisors have to say on Tuesday.
E/ yes, its a G25 red card (but as above pointed out it was connected to an alliance partner)
ROBOTS may not intentionally detach or leave parts on the FIELD.
Unread 21-03-2015, 20:52
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: RAMP TETHER
Originally Posted by Arhowk View Post
2E/ I'd also like to point out that loading litter from above the alliance station is also a foul
You'll want this Q&A.
Unread 21-03-2015, 21:10
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Re: RAMP TETHER
Originally Posted by Siri View Post
Ah, my bad. Good thing I'm not a referee or scores would have been really low.
Unread 21-03-2015, 21:20
Re: RAMP TETHER
No need.
You see, if you leave something on the field that isn't part of a robot, then it is removed from the field before the match--by you, or by the field crew (G8). And if you intentionally detach part of a robot, then you get a G25.
So if you bring a ramp that is part of a robot, it needs to stay attached to the robot no matter where the robot is. If it isn't part of a robot, you'll never be able to use it because it will be removed.
Unread 21-03-2015, 21:26
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Re: RAMP TETHER
No need.
Yes, I edited my post to clarify the point that the ramp was indeed connected to a robot and not debris as the initial post had stated. Thank you.
Unread 23-03-2015, 07:45
triumph69's Avatar
triumph69 triumph69 is offline
triumph69 is an unknown quantity at this point
Actually, it wasn't 2619 that had the ramp, it was the our 2nd pick, Grey matter with the ramp.
Unread 23-03-2015, 09:30
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
Re: RAMP TETHER
Originally Posted by Dominick Ferone View Post
At tech valley after we build our ramp and had or only weigh 3 pounds with our initial tether many teams copied the initial design to make super light weight ones. By today at least 5 or 6 teams more has tethers then the initial 3.
We were one of those such teams. We loved how simple and light your design was and made something very similar to it on Saturday. Thank you for offering to help us make our own version.
Unread 24-03-2015, 13:15
Cam_Team 2619's Avatar
Cam_Team 2619 Cam_Team 2619 is offline
Director/King of The Mill
FRC #2619 (The Charge)
Cam_Team 2619 is an unknown quantity at this point
Just to clarify, 2619 did not in fact use a ramp. 1506 did, that is correct.
2014 - King of The Mill
2015 - Mechanical Co-Lead/Human Player Backup
2016 - Mechanical Lead
2017 - Director
