Go to Post "Find a problem? Think of the three I's: Invent and Innovate to Improve!" - yash101 [more]
Unread 13-05-2011, 02:09
coolnerdguy1353 coolnerdguy1353 is offline
FRC #0114
coolnerdguy1353 is an unknown quantity at this point
Programming FRC robot in Visual Studio
I am just wondering if it is possible to program an FRC robot in C++ on Visual Studio. Is there a configuration file that I can download?
Unread 13-05-2011, 22:08
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Programming FRC robot in Visual Studio
I don't think Visual Studio comes with a PowerPC cross compiler and is not compatible with the vxWork binary format. So I would guess it is not possible.
Unread 14-05-2011, 15:46
runfrodorun runfrodorun is offline
FRC #0111
runfrodorun is an unknown quantity at this point
Not to mention that the code is structured differently, and the Microsoft Libraries are pre-compiled to x86. It may be possible however to use the IDE from Visual Studio, but the question is how long you are willing to spend to set that up.
Unread 21-03-2015, 09:20
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Is this still the case for 2015? We are looking for something with less issues than eclipse.
Unread 21-03-2015, 12:36
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
It could be theoretically possible. I know that it's possible to create a gradle script that would build for the roboRIO, and gradle has visual studio integration. However, I've never used the visual studio plugin before, so I don't know for sure.
Unread 22-03-2015, 11:11
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
If you're looking for a complete toolchain for VS that targets the roboRIO, I'm not aware of one.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 22-03-2015, 11:32
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
I believe there is a way to set up a makefile project, but it'd be a long job. You'd basically have to bind the "build" and "run" actions to shell scripts that do the actual compiling and deploying. You wouldn't get any debugging and _probably_ wouldn't get as good code completion/intellisense.
