Go to Post It's all about inspiration until people start complaining about teams getting lucky schedules and seeding first. - Anupam Goli [more]
Unread 22-03-2015, 20:58
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
pic: 3360's Oversteer pimped for Montreal regional!
Unread 22-03-2015, 21:03
ThunderousPrime's Avatar
ThunderousPrime ThunderousPrime is offline
All Drive. No Drama.
AKA: Nick Brown
FRC #1511 (Rolling Thunder)
ThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to beholdThunderousPrime is a splendid one to behold
Re: pic: 3360's Oversteer pimped for Montreal regional!
I was quite impressed that you were able to pull off that Recycling Container Stabilizer in between regional. How long did it take you to design it and how long did it take you to build and code it? (I asked one of students and I think he said it was built in about a day but I had to leave and I'm quite curious.) When you mentioned that the robot would look significantly different I thought it would either be a RC stabilizer or a Ramp of some sort and the former was right.
2015: Montreal Regional Chairman's Award
2014: Finger Lakes Regional Chairman's Award, Tech Valley EI
2013: Boston Regional Winners with 125 and 126
2012: Connecticut Regional Engineering Inspiration Award
Unread 23-03-2015, 00:53
Drive Coach
AKA: Antoine L.
we've built and designed the claw in a week, but we had to remove 5 pounds on our elevator in order to add it. We also made a ramp that we used during practices (just like 1114) but we didn't have to use it in playoffs.
The entire claw was made with a jigsaw 2 days before montreal and we were able to program it in 1 minute 37 seconds (not joking).
We also had an automatic sticking sequence using limit switches, but we broke them and didn't take the time to replace it.
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 23-03-2015, 08:19
Professional Stat Padder
What an impressive machine. Good luck at the World Championship!
(2015-Present)
Unread 23-03-2015, 12:03
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
How is the claw physically held together? Riveted sheet metal? brackets on the inside/outside that are rivited or bolted to the sheet metal? It's really cool that you only needed to use a jig saw and drill to fabricate it!
Unread 23-03-2015, 13:59
Drive Coach
AKA: Antoine L.
the sides are folded on each side to rovet the top and the bottom together, and the 2 moving parts are held together by the piston on the back
