Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 14-03-2015, 15:05
NathanCJohnson's Avatar
NathanCJohnson NathanCJohnson is offline
FRC #5517 (District 5517 The Engineers on Fire)
Team Role: Driver
Rookie Year: 2015
NathanCJohnson is an unknown quantity at this point
How does this robot have addressable LEDs still running when disabled?
I've been watching the webcast of the FIM Woodhaven district event and I saw team 1076's robot has addressable RGB LEDs that keep running after the match was over.
https://www.youtube.com/watch?v=XWKr9B_NIjw&t=2m38s
It's pretty cool, a line starts moving through the LED strip when the robot is disabled but I don't understand how it works. I didn't think that when disabled the controller would be able to continually send signals to the LEDs. Anyone have any ideas on how this works?
Team 5517 - The Engineers on Fire "Catching The Fire Of FIRST."
Facebook | Twitter | YouTube
Unread 14-03-2015, 15:29
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: How does this robot have addressable LEDs still running when disabled?
Digital output channels can still be controlled in disabled. I believe serial interfaces are as well. They could also have a coprocessor (arduino) controlling the strip...
So lots of possibilities.
http://team2168.org
Unread 14-03-2015, 16:38
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
They're running off a dedicated LED processor. RoboRIO only gives 'commands' via digital I/O. We do the same thing on our robot. We use an arduino, not sure what they use tho.
Unread 14-03-2015, 17:52
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
You also have these
http://www.adafruit.com/products/2238
which operate on the SPI communication channel, which has no data limits.
Unread 14-03-2015, 23:15
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
What information do you send to the arduino from the roboRIO? Is it just enabled/disabled state? Or do you send additional information?
We are looking to do the latter and have some questions about transferring the information from the roboRIO to the arduino.
Unread 15-03-2015, 00:01
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
the wpi libraries give nice functions for i2c communication as well as Serial (usb) communications.The arduino can also communicate using both of these methods. The only caveat is of course that you will likely have to write the code on both sides to properly interpret messages.
Theres also the fact that i2c and serial dont work very well on the roborio. Last I remember the i2c port on the actual roborio doesnt work and you need to use the mxp i2c pins.
Unread 15-03-2015, 13:22
Team Role: Driver
Rookie Year: 2015
Thanks everyone!
That's what I was kind of thinking, just wasn't really sure and didn't know the roboRIO's digital I/O works when disabled.
This year we just have a single-colored 12v LED strip plugged into the PCM (so we can toggle it). Next year we want to do RGB LEDs. If we use an Arduino and talk to the Arduino via roboRIO's digital I/O, does it just tell the Arduino which sequence to do (and then the Arduino has the actual code for the LEDs) or does the roboRIO have to send other data?
Unread 15-03-2015, 13:31
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Are you powering the LED strip through the PCM? This is not a good idea since the PCM can only output a maximum of 500 mA total on the solenoid channels. You would be much better off running it off a spike.
Unread 15-03-2015, 14:15
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I'm guessing there isn't an "MATCH OVER" state to allow teams to fold up / display "TEAM 1640" on their LED lights.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 15-03-2015, 20:27
Team Role: Driver
Rookie Year: 2015
Hmm, well it's been working okay for us. 500mA seems to be good enough for our LED strip (we bought a 16ft roll but aren't using all of it). Somebody else suggested it on another thread.
We don't have any spikes but might get one if it really isn't good to power LEDs through the PCM. The inspector didn't say anything about it though.
Unread 15-03-2015, 21:08
CronusWorks CronusWorks is offline
Electronics Mentor
AKA: Chris
FRC #1076 (Pi Hi Samurai)
CronusWorks is just really niceCronusWorks is just really niceCronusWorks is just really niceCronusWorks is just really niceCronusWorks is just really nice
1076 electrical mentor here.
The LEDs are driven by a Pololu A-Star 32U4 (more or less an Arduino Leonardo). This is connected to the serial output on the RoboRIO's MXP.
When powered on, it runs the idle animation and waits for serial data. Once it receives data, it does a boot-up animation and then the main one (stripes that move back and forth with the motors they're next to). If no data is received for 750 milliseconds, it does a shutdown animation and then back to the idle.
The RoboRIO sends a single byte every time it runs through the control loop during autonomous and teleop to tell it which motors are moving which direction. We aren't actually telling it to run the idle animation, it just falls back to it when there's no data.
If anyone's curious, we're powering the LEDs with one of these http://www.mini-box.com/DCDC-USB.
We initially bought it for our Jetson TK1, but that didn't end up making it onto the robot this year.
Unread 23-03-2015, 04:37
Frank Neuperger Frank Neuperger is offline
FRC #0842
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
Is it legal just to use an NPN transistor to drive the LED strip? drive the transistor from the DIO on the roborio. power form a fused output on PDB.
I don't see anything in rule 44 forbidding this.
Wires would have to be the appropriate gauge for the fuse on power distribution board.
FRC 842
FTC 4314
Team 0x27 (NURC, Sparkfun AVC)
Formerly with FRC 39 (now in cryosleep).
Unread 23-03-2015, 08:28
Team118Joseph's Avatar
Team118Joseph Team118Joseph is offline
The guy that did the lighting
AKA: Joseph Foster
FRC #0118 (Robonauts)
Team118Joseph will become famous soon enoughTeam118Joseph will become famous soon enough
The SPI bus on the Roborio can still run while disabled. This can be helpful for debugging issues on the robot while disabled on the field, providing feedback about connection issues and calibration details using the LEDs.
FRC Countdown Website: http://frccountdown.hosthorde.net/
FRC Countdowns App: https://play.google.com/store/apps/d...h.frccountdown
Unread 23-03-2015, 08:45
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Realize the inspectors have varying backgrounds. Some are more versed on electronics than others. The main function of the inspectors is to make sure your robot is relatively safe and meets the rules.
That would be a custom circuit. As long as it meets the rules for custom circuits, it is legal.
Unread 23-03-2015, 10:01
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Mschmeh144 is an unknown quantity at this point
Team 144 uses pololu strips and a arduino uno ( sunfounder uno to be exact), the arduino will continue adressing the strips even if there is no input from the roboRio. The arduino will default to the last used command or color I believe once the robot is disabled. Our robot does this too, but it doesn't do the "rainbow" unless the elevator is at the top when it's disabled, otherwise it just locks in at the solid color it was at ( our lights color code to the height of our elevator, and change accordingly )
Edit: I'm currently working on a project like this, but for the older 2014 bot.
