Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 23-03-2015, 10:08
Caleb McCune's Avatar
Caleb McCune Caleb McCune is offline
AKA: Argon
FRC #1058 (PVC Pirates)
Team Role: Student
Caleb McCune is on a distinguished road
Re: In b4 buttongate
Surprised that Chief Delphi isn't exploding over this right now.
Unread 23-03-2015, 10:27
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Unlike Dallas there is proof. Picture worth a thousand wild opinions.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 23-03-2015, 10:43
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Originally Posted by Carl C View Post
During the UNH District Event finals, a human player's button fell off, went through the chute, and ended up beneath the tote. When the stack was placed on the platform, the button was wedged underneath the stack. The rules state that the stack must be "completely" supported by totes to count, so the stack did not count.
I am not sure if that had any effect on the outcome of the match, but the whole thing was very bizarre.
This to me is a good example of Bureaucratic ruling.
Unread 23-03-2015, 11:08
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
Not sure what you mean here - the rules (and Q&A - in particular Q439) make it very clear that "support" is only transitive through other TOTES - not any other object that may be on the FIELD, regardless of whether it was intended to be there or not. Is this a literal interpretation of that? Yes, but if you start reading things into the rules that aren't there, then they become sort of "guidelines", not rules.
If I were a ref (which I'm not) the deciding factor for me would be if I could easily dislodge that button from the stack - i.e. is it just there on the edge of a TOTE, or is it really wedged in there? If the former, it scores - there is unambiguously no support being provided by the button. If the latter, then it doesn't score. From the picture, it could go either way. Of course, I defer to the ref at the match for the ruling, which was that it didn't score.
Unread 23-03-2015, 11:11
BrendanB BrendanB is offline
AKA: Brendan Browne
It should be noted that Frank Merrick was field side while the refs were discussing so the refs weren't coming to their own conclusion and they have to follow the rules put before them even if it might seem silly. The refs at UNH were extremely consistent with upholding the rule book including clarifying the rules when "can wars" started dictating who placed robots first.
While an honest mistake the rules are the rules and at the end of the day the decision had no bearing on the outcome of the match. Thanks to 58, 126, 133, 213, 501, and 4564 for making for an exciting finals match up.
1058 PVC Pirates 2016 - xxxx
Unread 23-03-2015, 11:29
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Quite clear from the picture (look at the gaps between totes, left and right, upper and lower) that the button is supporting the totes above it.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 23-03-2015, 11:37
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
While true that it shows a button supporting a stack. There is no part of the picture that indicates that it is the stack in question. As far as I am concerned its just a stack of totes with a button on a scoring platform on red carpet. Either way the stack itself wouldn't have changed the outcome of the match, and I believe (I don't know for certain) but I believe that the intent of the strict definitions of scored objects being supported is to prevent teams from engineering a way to artificially increase the scoring level on a bin. Again I have no way of proving that.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 23-03-2015, 11:39
AKA: Brendan Browne
Can confirm that is the stack in question.
Unread 23-03-2015, 11:42
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I would imagine it would prevent you, for example, from encasing a pile of totes inside your robot, driving the whole mess onto the scoring platform, and parking there. See? Totes are on the platform! Or building a cage that stored a bunch of totes and then sliding the whole cage onto the platform. Or a ramp, bridge, or other shenanigans of the sort.
I think it was primarily meant to acknowledge that litter would be strewn all over the field and that one of the challenges would be to make sure the tote was not stacked on top of litter (allowing this could also be a safety issue if the stack became unstable).
A button that accidentally fell down, though? That seems like bureaucratic ruling to me. A lot of the rules in the handbook say "The INTENT of this rule is to ___ while making exceptions for ___", this could have been one of them.
Unread 23-03-2015, 11:51
When you start making exceptions to rules based on circumstance you devalue the rules and those who enforce them.
Unread 23-03-2015, 12:27
Robonut
AKA: Mr. Lam
Rookie Year: 2015
True, and going by this, the judgement in the button scenario was valid and correct.
I'm just saying that the rule could have been worded differently. For example, G25 says "ROBOTS may not intentionally detach or leave parts on the FIELD" but then the blue box clarifies that "G25 is not intended to penalize ROBOTS that encounter accidental breakage (e.g. a failed MECHANISM that falls off), as those actions are not intentional."
They could have worded the "fully supported" rule differently. Granted it would probably be futile trying to define what was OK and what was not, hence the all-sweeping rule.
Unread 23-03-2015, 12:36
Enginerd
FTC #11722
What I meant by Bureaucratic is this:
Overly concerned with procedure at the expense of efficiency or common sense.
Unread 23-03-2015, 20:44
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Wink Re: In b4 buttongate
Originally Posted by bobl View Post
For what it is worth, Counting the stack would not have changed the outcome. Instead of 155 to 84 it would have been 155 to 126. Congratulations Team 133, BERT, 213, The Dirty Birds and 501, The Power Knights! The 142-141 finale was awesome! This event had a plethora of high scores and terrific robots. I am looking forward to seeing and working with all the teams again at WPI for the District Championship.
Yes, agreed, very exciting final matches!
Thanks to everyone who participated and congratulations to all the teams.
Too bad about the button thing, that was unfortunate, but as bob mentioned, it wouldn't have changed the outcome of that match.
The UNH District was a HOOT!
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
Unread 23-03-2015, 21:02
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Interesting.
It's a sad thing to occur but the rules are very clear on this and I think the call was fair. It didn't determine the outcome of the match so there shouldn't be too much drama over it, thanks for sharing.
Unread 23-03-2015, 21:33
DirtyBird213's Avatar
DirtyBird213 DirtyBird213 is offline
AKA: Dean Joyal
FRC #0213 (Dirty Birds)
Rookie Year: 1993
DirtyBird213 is on a distinguished road
Thanks for a great match..... For all the craziness it was amazing to finally get one under our belts. My 21st year with Dirty Birds and finally got a banner. Team of 8 that stuck with it!
On to WPI....Think DIRTY (Dirty Birds)
2015- NE Districts UNH District Event Winner
2003- BAE Systems Granite State Regional; General Motors Industrial Design Award.
Advisor KHS DIRTY BIRDS since 1994
