Go to Post ...Of course, all the scales in the world won't help you if your robot is 135lb two nights before the ship date... - J Flex 188 [more]
Unread 17-03-2015, 16:43
antonyebert antonyebert is offline
FRC #4993
antonyebert is an unknown quantity at this point
Turning On Robot Router
So, I know that we are not allowed to do any build on the robot after bagging. What I am wondering is if we can turn on the router? I want to fix some problems with our wifi connections, and to do that I need to turn the router on.
Unread 17-03-2015, 16:49
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Turning On Robot Router
Is the router on the robot, sealed in the bag?
2016: Lake Superior WFFA
Unread 17-03-2015, 16:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If your router is in the bag then no you cannot turn it on. "hands Off" would mean not turning on the power switch even if you could do it without opening the bag. If your router is outside the bag then you can do anything you want with. It is cots so it does not even go against you fabricated parts weight limit.
Unread 17-03-2015, 16:57
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
If your router is not in the bag with the robot, then that should be okay. If the router is in the bag, then it will have to wait. there are special rules regarding opening the bag before attending 2 day district events (section 5.6 in the administrative manual) but that won't help you if you aren't attending district events. In any case, somebody at your event will probably be able to help you.
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Once it's in the bag, you can't interact with it. You can't look at it. You can't measure it. You can't sniff it.
Unless if you need to do a quick demo that's less than 4 hours - but no fixing if it gets broken somehow.
Unread 17-03-2015, 16:58
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Wouldn't the robot need to be powered in order for the router to be on anyway? Meaning you would bagged your robot with a battery inside...
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 17-03-2015, 17:00
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Keep in mind when you are at the event, it will be required that you update your router with the encryption for that event. Which means, while at the event you will not be able to connect wirelessly to your robot, you'll need to tether it. If you have any questions on how that works, find a CSA (orange hats) or ask a robot inspector (yellow hats) for help.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 17-03-2015, 17:02
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
At the competition, the router will be reset and configured for the competition. There is not much you can do to "fix it" that won't be undone.
If your problem is with the Driver Station, then the CSA's (orange hat guys) and FTA's at the event are great at helping with that.
Unread 17-03-2015, 20:29
EricH EricH is online now
Some of the yellow hats, when confronted with more than a basic control system problem, will instinctively look for the nearest orange hat. I suggest going straight to the orange hats, saves some time.
Unread 23-03-2015, 10:31
FRC #4993
Alright, I guess I'll just have to try and figure out the problem without testing it out. I'll make sure to ask these orange hat people at the event. Thank you guys!
Unread 23-03-2015, 12:54
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
After you image your router at the competition you can only tether directly with an ethernet cable to your robot. Even if it is in AP mode you still can't connect. You need to reset the router with a small screwdriver or paperclip, put it into AP mode, and reconfigure it like you did at the start of the season.
Unread 23-03-2015, 14:48
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
You can also use a USB cable to connect to the rio.
2013 - Present MAR Control System Adviser and FTAA
2009 - Present Programming an Electrical Mentor Team 41
2005 - 2008 Team 41 Programmer
2008 NYC Regional Winner
Unread 23-03-2015, 16:18
Ozuru's Avatar
Tethering with a USB Type B cable directly to the RoboRIO allows you to directly interact with your subnet and its respective elements (such as a network IP cam) in the form of 10.TE.AM.IP?
Unread 05-04-2015, 01:46
AKA: Garrett Dicken
Somewhat.
When you use the USB interface your computer will have an address of 172.22.11.1 with a subnet of 255.0.0.0 (might be 255.255.255.0) and the rio will have be 172.22.11.2. IP cameras will not work, however any communication to the rio, such as the driver station or dashboard WILL work. That includes USB camera feeds. You can SSH into the rio through this, and I suspect you could ping an IP camera. It should find it via mDNS.
