Go to Post Nothing beats the local hardware store :). - Mike Martus [more]
Unread 23-03-2015, 16:18
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: FMS enabling sequence?
Originally Posted by Jared Russell View Post
I would think that each DS is running its own polling loop asynchronously at ~50Hz (the rate of driver control packets). So even if the disabled bit toggles simultaneously for all six bots from the FMS (which it doesn't since the FMS->DS packets must be sent serially, but it ought to be close), there could be a 20ms swing in when each DS sends the first enabled packet depending on the phasing.
( I am just guessing at how the FMS and DS are architected here since I don't think it is publicly documented; please set me straight if I have made an incorrect assumption. )
Realistically, with our wireless links, synchronization is always going to be hard.
There's also another 20+ ms delay caused by the wpilibs if you use anything but the sample robot template. Could end up being up to 40ms depending on how the fpga loops.
Team 4488 - Mentor 2013-2016
Unread 23-03-2015, 16:33
Jared Russell's Avatar
Taking a year (mostly) off
Please elaborate?
Unread 23-03-2015, 16:47
Please elaborate?
In LV I know that it runs disabled for 1 extra loop after it receives an enabled packet. Then it will run auto on the next enabled packet.
Based on the last time I looked in the Java code, it will run auto init, then the next packet run auto periodic. So unless you are starting your sequence in auto init, it wont run motors until it gets a second enabled packet.
Note that the whole time this is happening, the fpga is enabled, so it will run 20ms with the values it last receives. This is why there are times the robot jumps between disabled and enabled.
Unread 23-03-2015, 16:59
I do not think this is currently the case in Java (for IterativeRobot at least). It does check for the new data flag (via nextPeriodReady()), but this flag is not cleared after calling autonomousInit(), so autonomousPeriodic() should be invoked on the first packet
Unread 23-03-2015, 20:53
Ah. They might have changed that then.
However, LV still does do this, and runs disabled one last time, and still has to wait for another packet to be sent before actually enabling auto. so auto in LV will have a delay of one packet before actually running auto code.
Unread 23-03-2015, 16:45
Jared's Avatar
Jared Jared is offline
Here's a frame by frame of the Dallas Q39 (118 and 3310 in same match).
118 is going for their 3 tote auto, 3310 is going for containers, and a team 932 (middle of field red side) is driving forward at a high speed in auto mode.
Frame 1 - Yellow lights on field illuminate
Frame 2 - Red/Blue DS stack lights illuminate
Frame 3 - Nothing
Frame 4 - 932 tips back and begins movement
Frame 5 - 932 continues to move
Frame 6 - 3310 begins to drop arms
Another frame by frame on Dallas F1 (118 grabbing from step, 148 auto)
Frame 2 - stack lights
Frame 3 - Nothing
Frame 4 - 148's arm moves
Frame 5 - 118 drops arms
From watching a few other matches, there is usually a different number of frames between lights and robot movement for teams like 118 and 3310.
