Go to Post To quote Dylan, "When you aint got nothing, you got nothing to lose". - KenWittlief [more]
Unread 23-03-2015, 10:46
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
2015 OPR After Week Four Events
The OPR/CCWM numbers after four weeks of events have been posted, please see
http://www.chiefdelphi.com/media/papers/2174
If you find any error or have any questions, please let me know.
There are a number of points I would like to make:
1) FIRST started showing DQ'd teams with "*" before and after the team number. I did not have time to change my program to "handle" that so I just took out the "*" manually. This means if somebody tries to run the macro with Cntr-Shift-O and there are DQ'd teams for that event, they will get an error message. As a work around for now until I change the program, just manually delete the "*" after you import the data using Cntr-Shift-P.
2) I don't know what FIRST HQ did this week. For the first three weeks, it takes almost a minute to refresh the Standings and Match data. Last night when I ran it, it was lightning speed, even faster than in previous years. Thank you FIRST.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 23-03-2015, 13:25
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: 2015 OPR After Week Four Events
How do you add pictures to the database? BTW thanks for doing this. Interesting to compare to our live scouting.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 23-03-2015, 16:44
Ed, how did you compute world component OPRs this time around?
Unread 23-03-2015, 17:01
Ed Law's Avatar
Same way as last week.
http://www.chiefdelphi.com/forums/sh...05&postcount=7
Instructions are in the sheet called "Instructions" which is the first tab from the left. You have to take the pictures of the robots. The pictures need to be in the same directory as the Scouting Excel file and be named team#.jpg, e.g. 2834.jpg or 5137.jpg
Unread 23-03-2015, 17:06
Were you able to speed up the computation ?
Unread 23-03-2015, 20:38
Ed Law's Avatar
Thanks for all your suggestions. I don't think Excel or my computer has those options. I really don't have time to investigate. My solution is start running the macro, walk away and do other things around the house and go back in an hour. I don't think it would need an hour but it was done when I got back.
The part that takes the longest time is A(T) * A. To not assemble the A matrix like you suggested would require a lot of reprogramming which I don't have time. Also when calculating the component OPR I have to solve A x = b 6 times. It may be better to just assemble A once instead of 6 times. As for sparse matrix solver, it will certainly help but A(T) x A takes a lot longer than the equation solving part. I am waiting for a VBA version of the sparse matrix solver to be available and then I will switch over from using Cholesky decomposition.
Unread 23-03-2015, 22:21
Did you try making [A], [A'], and [N] integer instead of floating point? If VBA supports integer matrix multiplication that would probably substantially reduce the computation time. Use the native word size of your machine for the integer size. Your machine is probably 64bit word size? So make the elements of each matrix 64-bit integers.
Once you've created [N]=[A'][A] you can use that [N] matrix to solve for all 6 components at once.
[N][x]=[d]
If you make [d] a 6-column matrix instead of a vector you can solve it once and get a 6-column matrix [x] with all 6 solutions.
Unread 24-03-2015, 23:01
Ed Law's Avatar
[N][x]=[d]
The solver I have is expecting a vector d so I cannot use a 6 column matrix like you suggested. I agree it will have some improvement in efficiency but I cannot do it that way.
Unread 25-03-2015, 10:08
Are you still using ALGLIB? It has a Cholesky solver that accepts a matrix for the right-hand side.
Unread 25-03-2015, 10:52
Ed Law's Avatar
Yes I am using ALGLIB. I am using SPDMatrixCholeskySolve.
Unread 25-03-2015, 11:23
Take a look at spdmatrixcholeskysolvem
Unread 25-03-2015, 12:28
David8696's Avatar
David8696 David8696 is offline
I.A.A.R. Lord
AKA: David Bluhm
FRC #2485 (W.A.R.Lords)
David8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud of
I'm wondering if there's a web database out there of this data that could be queried real-time for a scouting app. I know TBA has top 15 OPR rankings for individual events, but I'm fairly certain there's no storage of full-season OPR's (or the OPR's for more than the top 15 robots at an event). If I'm wrong, please let me know; if I'm right, I'd love to know where I could find something like this.
2015 Inland Empire Regional Innovation in Control Award
2015 IE Quarterfinalists
2014 Highest Unpenalized Score in Aerial Assist (370 points with 51 and 1918)
2014 Archimedes Semifinalists
2014 Las Vegas Regional Champions
2014 NVLV Excellence in Engineering Award sponsored by Delphi
2014 San Diego Regional Finalists
2014 CASD Quality Award sponsored by Motorola
2013 Inland Empire Regional Winners
2013 IE Excellence in Engineering Award sponsored by Delphi
2013 Battle at the Border Winners
2013 BATB Giving Award
2013 BATB Most Valuable Team
2013 San Diego Regional Finalists
2013 SD Creativity Award sponsored by Xerox
Unread 25-03-2015, 12:37
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
TBA stores the per-event OPR for every team at the event (although only the top 15 are displayed).
There is an API Endpoint for Stats which will return OPR, DPR, and CCWM for each team attending the event.
We're planning on adding more insight data to the API in the next offseason, and we'll consider doing full-season OPR.
