Re: Anti-tipping algorithm
Almost like a certain type of two wheeled human transport device....
Cool idea. For anyone that wants to try this. You don't need to buy any additional sensors, the RoboRio has a built in accelerometer, and you can use that alone to sense pitch and roll angles, depending on how the RoboRio is mounted with relation to your Robot.
Here is some code to get you started: Code:
public static double getAccPitch() {
double Y = Robot.accel.getY();
double Z = Robot.accel.getZ();
return Math.atan2(Y,Z) *180 /Math.PI;
public static double getAccRoll()
double X = Robot.accel.getX();
return Math.atan2(-X, Math.sqrt(Y*Y + Z*Z)) * 180/Math.PI;
This assumes a horizontal, mounted, upright RoboRio. You will need to modify the methods if you mount your RoboRio vertically by changing which acceleration vectors it uses. To access the built-in accelerometer in the RoboRio simply do this: Code:
public static BuiltInAccelerometer accel; accel = new BuiltInAccelerometer(); Hope this helps, Regards, Kevin Last edited by NotInControl : 24-03-2015 at 15:19. |
As Jared mentioned, a pure accelerometer solution is going to have noise and accelerations in it. Filtering can clean it up some what to give an estimation of gravity but the robot acceleration is still there. The advantage to the Navx MXP is that the chip handles the fusion of 3 a axis accelerometer and a 3 axis gyro.
It also can fuse a 3 axis magnetometer also but we do not use the mag. Pitch and roll are very solid and excellent for this use. Yaw is another subject. In it's current form the Navx MXP does need to be horizontal. |
A simple Euler linear filter can be used if one desires. It is a autoregressive infinite impulse response moving average. Code:
accelX = (accelX * alpha) + (Robot.accel.getX() * (1.0 - alpha)); This is the most basic filter you can implement in my book, and it does a pretty good job. There are more robust filters if you ever wanted to experiment with them. Two popular filters to try to smooth acceleration data out would be a median filter, or a Butterworth filter. They are popular because they are relatively easy to implement in code. If you have the means to use a Gyro to measure the axis of rotation you care about, that is the sensor I would recommend for this application... if you don't, or want to experiment otherwise, it shouldn't take too much effort to use an accelerometer to have a similar implementation. Last edited by NotInControl : 24-03-2015 at 16:18. |
#7
Anything to keep any bot from tipping over (that works), is absolutely great. (Glad to see others quickly share all kinds of solutions often, what helps one in this game absolutely helps all! Those QPA's will skyrocket too across the board, as will Playoff averages).
So far I have seen a ton of very nice saves, some very smart other drivers righting tipped over bots rather quickly on their alliances after mishaps that, are somewhat salvageable, and seen some actually right bots fully laying flat on their backs....Call those "The friendly emergency forklift towbots" when in trouble drivers. (Look left or right drive team when in trouble, as the AAA, emergency OnField & FieldSide Service, is actually standing right there next to you!) No need to dial 911. _____________________ Then I asked myself...How can this apply to our team.... We have an external forklift type mainly HP fed stacker (though that isn't it's only possible usage), & the cg is quite centered unloaded). And once loaded they tip back the elevator and the entire stack for great centered cg again, line up at the scoring platform and tip the stack back forward. So tipping of robot isn't a problem...so far. Tipping of the 6 high/capped stack is of course more than possible, if a single mecanum wheel gets up on the ramped edge, and the other one off on the carpet (they have felt that wrath and learned from it highly), and if the stack isn't really straight. But, unloading perpendicular to the scoring platform is an easy adjusted driving solution there. As long as stack is locked properly in place (paying full attention & careful stacking and aligning totes along the way up of course, they are getting better and better w/ each match in aligning during the build). Once loaded W/ a 6 tote high stack or 5 tote w/ RC capped laying on side, our drivers can actually do in practice fairly fast 360 spins and not drop anything and or tip over stack or bot. _______________________________ Then I read this particular found coding/software solution thread about some who have that existing cg problem (and having seen some bots on vids have the loaded, or the unloaded, mainly unloaded cg issue in matches previously, it is a very simple & easily performed solution to the major tipping problem..."Segway Your 2015Bot" (what a tribute to Dean Kamen's 2 wheeled transport invention BTW). I can't imagine yet, what the capabillities of the Robo Rio and plug in boards (and many different hardware/programming itterations), will be, just 3 years downline. (Already, they are nothing short of amazing). The sharing across the board is too (and appreciated), it certainly appears to have made our first switchover year from WCD to a mecanum drivetrain much smoother it appears so far. I guess the team waited just long enough there. (Though some previous now graduated and in college students on the team, sure wanted to go that direction over the last few years I know). There was lots of talk, very little action as long as defense and pushing were keys. I hope our team does not ever (this year), see it (this thread), and actually try it (this year). They just designed for cg loaded & unloaded, so they'd be creating huge problems I would think (fixing something that isn't actually broke), and nastily imagine...Though I could be wrong also. I'd have extreme nightmares even thinking about the nasty possibilities of watching that tipped back fully loaded elevator start the Segway Shuffle and balancing act....That bot would surely go down in flames if it did....(Beyond looking rather a bit tipsy...as in having consumed adult beverages tipsy). _______________________ Those installing the solution so far...Any way you developed so far, to shut it off when you do not need it? (As in when the cg is in the full comfort zone?) Such as a driver station button hardware solution, or another programming tweak solution? Or does it just quickly correct and forget? Just wondering about an unloaded ok cg bot going quickly over the scoring platform ramps, and the possible affects of that positional vertical lean X 2 (up then down), when driving over...Does the bot get jerky there? (I just imagined one that may start dancing on the ramped portion, as it tries to quickly drive over the hump). Or one in auto hitting the ramp and "Doing the Segway...Right Into The Zone!" My hat is off to all those that designed those plug in boards (and those adopting them), and made them avail. to all commercially the very first RoboRIO changeover year. The sky appears the limit, and the game, and timing for this game was absolutely right on there. Early adoption of any technology is always fun. Working adoption is really fun. But, finding simple solutions to very complex problems is best. |
#8
In all seriousness though, this sounds like quite the interesting idea. |
