Go to Post It's not hard, it just requires thought. - Matt Leese [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 22-03-2015, 13:29
FrankenmuthK's Avatar
FrankenmuthK FrankenmuthK is offline
FRC #5215
FrankenmuthK is an unknown quantity at this point
Arrow NEW TO PYTHON
New programmer to python... Looking for tips, instructions on how to program for FRC, and anything else I need! Thanks
Steagles 5215
Unread 22-03-2015, 17:44
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: NEW TO PYTHON
Welcome. You have made a great choice in switching to python.
http://robotpy.readthedocs.org/en/la...ide/index.html
This is documentation for wpilib, python style. Most of what you are looking for is in here. For choosing a 'method' of robot programming, iterative is pretty straightforward, and if you are up to it go with sample robot. Stay away from command though.
If you have any more questions, just ask. Robotpy (the libraries for FRC python) has a freenode channel, http://webchat.freenode.net/ #robotpy and 1418 programmers are generally on, and we're always glad to help.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 23-03-2015, 19:20
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
Re: NEW TO PYTHON
Why do you recommend that to stay away from command based?
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 23-03-2015, 20:02
ArchdukeTim
Re: NEW TO PYTHON
Even though FIRST recommends using Iterative or Command Based, command based is generally found to be harder, but more so that Iterative/Sample are just so easy in python. There's also more support for them (forum wise).
Unread 23-03-2015, 21:59
FRC #5215
Re: NEW TO PYTHON
What would you suggest for a new python programmer?
Unread 23-03-2015, 22:53
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Re: NEW TO PYTHON
Now i'm curious, did you see my team's display about python at the Great Lakes Bay Reigon Competition?
If you have never programmed in python before, you might want to start by learning the basics of the language before diving into programming FRC robots. I have found that codeacademy.com has a pretty good primer for learning basic python.
My Github Repositories
Unread 23-03-2015, 22:57
ArchdukeTim
Re: NEW TO PYTHON
Dustin Spicuzza (virtualD) has also created a python learning package called pybasictraining. You can find it in Team 1418's github, https://github.com/frc1418/pybasictraining.
Unread 23-03-2015, 23:02
ArchdukeTim
Re: NEW TO PYTHON
Well... that's tough. Because python is so versatile, the only real difference between iterative and sample is that in sample you create your own loops. This can, however, be hard. So I think your safest route would be iterative. It is very easy to understand and you get the same capabilities as sample robot.
Unread 24-03-2015, 00:00
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: NEW TO PYTHON
As said previously, learning the python language in general is a good place to start.
Python in FRC has a simulator that you can use to test the programs out that you create, and there's a number of examples available to look at:
Unread 24-03-2015, 00:15
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: NEW TO PYTHON
Command based is made for more object orientedness. If you really want to do those the simplest way would be to use java/c++. Stick to iterative though because you seem many teams trying to do their own stuff in simple and it ends up not being simple. Python is still a great language for frc and i hope to see it more developed.
Unread 24-03-2015, 09:31
techplex's Avatar
Blake B
AKA: Blake
Re: NEW TO PYTHON
This year we used Java and command based. For the most part we love how command based allows us to have the appearance of doing multiple things at the same time. A couple of the student members have got a pretty good handle on how to write command based code.
As the programming mentor I find java to be very verbose. We find eclipse to be very cumbersome and heavy. I severely miss the days of netbeans. We were thinking about trying python with JetBrains pyCharm.
@x86_4819
I did not see you display. Is there photos of it anywhere? My team is from Maine so we haven't quite traveled that far.
Blake
Unread 24-03-2015, 10:58
ArchdukeTim
Re: NEW TO PYTHON
We find eclipse to be very...heavy.
Why do you find it heavy? Is there something wrong with earth's gravitational pull where you live?
Unread 24-03-2015, 11:01
x86_4819's Avatar
computer-whisperer
Re: NEW TO PYTHON
Sorry, I was trying to ask FrankenmuthK.
Unread 24-03-2015, 14:03
FRC #5215
Re: NEW TO PYTHON
I did not see it
Unread 24-03-2015, 14:04
FRC #5215
Re: NEW TO PYTHON
Where would I find the simulator
