Go to Post It also annoys me that I can't get all my pants with zebra stripes - marshall [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 18-03-2015, 11:08
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Re: Team 1538 / The Holy Cows - 2015 Robot: Daisy Quickstep
Originally Posted by JesseK View Post
What about your 'pincher' requires so much power? Does it do more than pinch? What does it pinch?
Do you have any limit switches anywhere on your robot?
Do you guys powdercoat your stock, and then drill into it?
1) Cans, totes, robots, people, etc. Two motors are dedicated to the 'pinching' function, the other two power the rollers on the pincher.
2) Nope. We've done a fair amount of control theory work and implementation this year. It's been a great experience for our students to be exposed to even more practices that are fairly common in the controls industry.
All of our rezeroing, minimum and maximum positions are determined by using a combination of position gathered using a quadrature encoder and monitoring output current and output voltage.
For example, we'd limit the upper end of our elevator travel based on an estimated position and then we'd calculate how much power is going into the elevator to prevent a motor stall condition.
After profiling the current draw, we determined that it requires a little bit of logic to figure out if we're indeed stalling the gearbox, or lifting a bunch of totes.
We'd also rezero our elevator when it returns to its minimum position. Essentially, we'd allow for the elevator to run past the minimum position. Once we've detected that we're not moving anymore, the position is past the minimum position (our elevator has a spring loaded return cable), and current has trended upward, we can safely say that we're at the minimum position. We'd then allow the elevator to back drive itself via the spring to its natural state where we'd then reset the encoder.
Finally, we're using a quad encoder on our pincher gearbox along with two different PIDs. One PID handles position control so that our drivers can quickly acquire game pieces. Once the game piece is kinda-sorta in our possession, we'd switch to a current based PID.
This ensures that we'd be placing almost an equal amount of force on what ever we decide to grab. This configuration works on game pieces in any orientation. Cans fallen over, Cans upside down, totes from the wide side, totes from the long side, totes that are upside down, you name it.
3) We do not powdercoat our stock and do post machining. It just happened to be on that part, we kind of forgot a few holes. Careful measurements and some patience later along with a handheld drill, we'd have some pretty precise holes.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Last edited by kiettyyyy : 18-03-2015 at 11:16. Reason: Forgot about the rollers...
Unread 18-03-2015, 11:18
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Are the rollers on the "pincer" polyurethane tubing like McMaster carries?
"A genius is just a talented person who does his homework" T. Edison
Unread 18-03-2015, 11:20
kiettyyyy's Avatar
Maybe
Originally Posted by Kevin Kolodziej View Post
One question: How do you intend to satisfy R2 and have numbers visible from all sides of you robot?
We took them off for the photo shoot. They look a bit funny to us.
-Kiet Chau
www.team1538.com
Unread 18-03-2015, 13:16
Gweiss96's Avatar
Gweiss96 Gweiss96 is offline
AKA: Garrett Weiss
FRC #3309 (Friarbots)
Team Role: Operator
Gweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to beholdGweiss96 is a splendid one to behold
I just have to say, this is the coolest looking robot I have seen for this competition. The Holy Cows never fail to impress me with their amazing powder coating. Well done.
Unread 18-03-2015, 13:47
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Excellent Bot saw it up close and personal. So glad to see THE CLAW working on final bot! Their wire management is crazy good.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 18-03-2015, 14:03
RoboChair's Avatar
AKA: Devin Castellucci
That wiring job is so sexy I would date it.
Unread 18-03-2015, 14:22
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
This is the most beautiful robot I've seen this year. Look at those curves, those edges, that wiring, the sponsor plates...holy cow.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 18-03-2015, 14:38
hunterteam3476's Avatar
hunterteam3476 hunterteam3476 is offline
AKA: Hunter
FRC #3476 (Code Orange)
hunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud ofhunterteam3476 has much to be proud of
What a beautiful Robot, I can't wait to compete with this at SDR.
http://www.TeamCodeOrange.com
2015 - Championship - Tesla Champions, #2 pick
2015 - San Diego - Regional Chairman's Award, #1 Pick, Finalists
2015 - Inland Empire - Engineering Inspiration Award, #2 Pick, Finalists
2014 - Championship, Excellence In Engineering Award
2014 - Las Vegas- #3 pick, Finalists
2014 - San Diego - Regional Chairman's Award, Regional Imagery, #2 Alliance Captain, Semi Finalists
2013 - Championship - Newton Champions, #3 pick
2013 - Inland Empire - Innovation in Control Award, #2 Alliance Captain, Finalists
2013 - San Diego - Industrial Design Award, #4 Pick, Semi-Finalists
2012 - San Diego -Regional Winner, Excellence In Engineering Award
2011 - San Diego - Judges Award
Unread 18-03-2015, 15:43
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Impressive, intimidating, and (most importantly) inspiring...as always! I'm looking forward to seeing you play in Arizona and then seeing it for myself in San Diego.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 24-03-2015, 11:51
Maldridge422's Avatar
Maldridge422 Maldridge422 is offline
➅➀➈
AKA: Matt Aldridge
FRC #0619 (Cavalier Robotics)
Maldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant futureMaldridge422 has a brilliant future
As always, a gorgeous robot with incredible wiring. What kind of connectors are those coming off of the talons? What are the advantages of them compared to Andersons?
Unread 24-03-2015, 12:28
kiettyyyy's Avatar
Those connectors are Deans Ultra connectors. We mainly chose them for the form factor. Also, the plug, including the solder joints, have less resistance than a piece of 12 awg wire of an equivalent length.
-Kiet Chau
www.team1538.com
