Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 24-03-2015, 14:23
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Updating Speed Using Ultrasonic Sensors
* Put your robot on blocks so it wont drive.
* Add print statements to your code that lists the distance and motor output value for each loop itteration.
* Run your code while moving an object in front of the ultrasonic sensor.
There's got to be a case where your if/else logic doesn't result in the motor.drive() method being called.
Also, why are you using the setSensitiviy method, that affects turning not rate of travel.
See: http://team2168.org/javadoc/edu/wpi/...obotDrive.html
http://team2168.org
Last edited by otherguy : 24-03-2015 at 14:29. Reason: question set sensitivity use
