Go to Post Pessimism and optimism are both contagious. - Taylor [more]
Unread 24-03-2015, 15:01
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Plastic Clamping Blocks
This year VEXpro introduced plastic clamping gearboxes & bearing blocks.
We used the plastic clamping blocks extensively with our 2015 DiscoBots' robot.
We experienced a couple failures but for the most part we have been very happy with the results.
I will post a picture of a few of the failures on our website in the near future.
Any other interesting experiences from teams using plastic clamping blocks ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 24-03-2015, 15:50
SJaladi's Avatar
SJaladi SJaladi is offline
Mechanical Mentor
AKA: Sarath Jaladi
FRC #1923 (The MidKnight Inventors)
SJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond reputeSJaladi has a reputation beyond repute
Re: Plastic Clamping Blocks
We used plastic clamping blocks in conjunction with the single reduction clamping gearboxes for our elevator gearboxes. We experienced a problem where if ALL the thru-bolts, not just the clamping ones were not installed, the gearbox cracked under high tension loads. This is partially because we cantilevered the chains that drive our elevator, but once we drilled and installed all the thru-bolts, this problem was alleviated and our elevator ran much more smoothly.
The clamping gearboxes worked like a charm for this purpose and they were super easy to install. Overall I would highly recommend both these products, but make sure to mind the types of loads you are placing on them. They are plastic at the end of the day, and will fracture if loaded too heavily. I'll try to dig up a picture from our cad of how we implemented them.
Unread 24-03-2015, 16:33
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We used them in our drivetrain this year, but not in our elevator. For a game with more severe shock load requirements (read: defense) I would have been more concerned about their plastic construction, and that might have kept me from trying them. I am glad we did.
Through two events and 34 matches so far this season, they are holding up fine. I would use them again, possibly even when we need to play defense in some future game.
Richard Wallace
since 2003
Unread 24-03-2015, 16:42
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Excellent, and inexpensive as well. I look forward to hearing more about these.
Unread 24-03-2015, 17:41
philso philso is offline
FRC #2587
Be sure not to over-tighten the fasteners. Someone over-tightened the two screws holding the motor on one of the clamping gearboxes. The screws have a fairly small head and they completely "crushed" their way through the plastic. The motor popped off with very little effort.
Unread 24-03-2015, 19:35
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
This. We ruined two by overtightening. It is very easy to not realize when they are tight.
Sleep? What is that? A rare Pokemon?
Unread 24-03-2015, 20:37
Nyle's Avatar
Nyle Nyle is offline
FRC #0422 (The Mech Tech Dragons)
Nyle is just really niceNyle is just really niceNyle is just really niceNyle is just really nice
We also did that to one of ours. Also watch out for over tightening the bolts that clamp them to or go through the 2x1; although doing so didn't seem to stop the bolts from holding the gearbox in place, if you start spinning the nut it will strip out the hexagonal shape that holds it in place, making it nearly impossible to remove the bolt without destroying half of it to be able to get a wrench around the nut.
We also found that one of the clamping bearing blocks had the inside half crack into two pieces during Palmetto. I didn't notice any problems as a result of it though; we replaced it as soon as we noticed it had happened. I believe that this was one of the ones supporting a wheel (6" VEXpro mecanum, cantilevered out with about .75" of space between it and the bearing IIRC). I wouldn't be surprised if this was the result of something dumb we did though, these sorts of things always seem to end up being that way.
Other than those two issues though they've worked great for us. We used four three stage gearboxes (one plastic clamping gearbox, two plastic clamping bearing blocks each) on our drive-train. My only major complaint is that putting the holes in for the bolts going through the 2x1 tube is a real pain to do without putting the piece on the mill or drill press since the plastic pieces can't be used as a reference to drill through; this makes putting them onto an already assembled structure a pain, although this can be easily avoided with a bit of forethought and planning.
Unread 24-03-2015, 21:11
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We're using both on drive and it's working fine for us. 4 pairs (gearbox + bearing block) x 4 wheels.
Unread 24-03-2015, 22:32
TCMJ1816's Avatar
TCMJ1816 TCMJ1816 is offline
Peter
AKA: Peter Hartnett
FRC #1816 ("The Green Machine" (Alumnus))
TCMJ1816 will become famous soon enough
We are running Versa Planetary into the input of the clamping gearboxes with much success. At our first regional we had one failure on the clamping gearbox which we have decided came from a combo of being over-tightened and strafing into the scoring platform causing an abnormally large side load. They are cheap and super easy to install, just keeps spares on hand.
Unread 24-03-2015, 22:44
maxxman maxxman is offline
maxxman is on a distinguished road
Team 4618 has used both the clamping gearbox and bearing blocks on our drive train. We run 6 inch vex mecanum and they have lasted about 2 hours of driver practise and a regional without fault
Unread 25-03-2015, 01:51
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We used the clamping gearbox on both our practice bot and our competition bot without any issues. We also used the plastic WCD bearing block on the practice bot, but the metal version for competition. We have so far logged around 50 hours on the practice machine, and maybe 20 on the competition version, and have zero incidents. We have twice rebuilt our 10:1 versaplanetary box used for the elevator though; considering what we put it through that's hardly a hassle.
We have worn out three sets of orange Banebots intake wheels, and have beefed up our 3D printed parts a few times. I can't say enough how refreshing it is to not have defensive damage to deal with after each round!
Unread 25-03-2015, 01:56
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I love the plastic bearing blocks. Cheap. Simple to use. Don't need precision holes. And work in just about every place if used correctly. The only thing plastic we have had a problem with so far is the plastic hubs. Plastic versa hubs do not like thunderhex in a high torque load and they especially do not like hard stops with thunderhex. Other than that, I would purchase all of these again
Unread 25-03-2015, 02:01
mrnoble's Avatar
teacher/coach
I'm sure there is constructive criticism to be had for vex this year, as in any year, but really. I am nothing but impressed. Two years ago I started searching everywhere (like, worldwide) for a product exactly like what they produced with VersaFrame. What a company.
Unread 25-03-2015, 07:42
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We're running four of the gearboxes and one of the bearing blocks--happy with the results.
I'll echo everyone else's comments about tightening on the gearboxes--we have to make sure everyone has proper training before they attach/detach any bolts from the gearbox due to risk of deforming the plastic.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 25-03-2015, 08:00
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Running 4 aluminum clamping bearing blocks on the drive train, 1 plastic clamping gearbox as the first stage of the lift.
For the drive train blocks, we had to shave away some powder coat in order to get these on after powder coating. No big deal - they are tight-toleranced for a reason.
There wasn't much finagling to get the plastic clamping gearbox onto the powder-coated rail it lives on. It still slides for tensioning, but takes a lot more force (expected).
Do any teams have experience with these plastic bearing blocks on powder coating?
