#16
Re: Team 1515 Presents MorScout
Thanks for making your scouting application available. I down loaded and installed node.js. After loading node.js, I opened the command window by selecting node.js from the start menu. At the print I type node --harmony userManger and it is not working.
Here is what is reported when I try the node comand: node --harmony userManager SyntaxError: Unexpected identifier at Object.exports.createScript (vm.js:44:10) at REPLServer.defaultEval (repl.js:117:23) at bound (domain.js:254:14) at REPLServer.runBound [as eval] (domain.js:267:12) at REPLServer.<anonymous> (repl.js:279:12) at REPLServer.emit (events.js:107:17) at REPLServer.Interface._onLine (readline.js:214:10) at REPLServer.Interface._line (readline.js:553:8) at REPLServer.Interface._ttyWrite (readline.js:830:14) at ReadStream.onkeypress (readline.js:109:10) Any ideas as to what I may have done incorrectly? |
#17
Whenever I try putting in "sh$ node --harmony userManager", the command prompt says that 'sh$' is not recognized as a batch file or operable program... Can you help me please?
#18
Ok, I fixed the previous error, but now I can't start the server. It gives me the IP Address, but then it throws the following error:
events.js:85 throw er; //Unhandled 'error' event Error: listen EADDRINUSE at exports._errnoException (util.js:746:11) at Server._listen2 (net.js:1129:14) at listen (net.js:1155:10) at net.js:1253:9 at dns.js:85:18 at process._tickCallback (node.js:355:11) at Function.Module.runMain (module.js:503:11) at startup (node.js:129:16) at node.js:814:3 I have no clue what is going wrong here, so any help would be appreciated! |
#19
I also can't submit any feedback. I'm not logged in, but i think it should be allowed even if you aren't logged in.
#20
Edit: I just got an email back that fixes this error. All you have to do is change Code:
node --harmony server Code:
node --harmony server 8081 Last edited by chiefwebmaster : 24-03-2015 at 19:13. |
#21
This might be a strange question, but how can we use this without WiFi at events?
